Dot numbers
Discussion in 'Ask An Owner Operator' started by Kodaroda1, Feb 6, 2024.
  1. Kodaroda1
    Kodaroda1 Bobtail Member
    31
    21
    Apr 27, 2023
    Do the mc and dot numbers have to be on both sides of the truck or just one side?
    77fib77 Thanks this.
  3. Judge
    91,783
    Dot numbers only, on both sides.
  4. Burnt Clutch
    Burnt Clutch Bobtail Member
    6
    4
    May 6, 2021
    it would be a good idea to put the last six of the VIN. i remember a few states like colorado its either required or theyll pull you in the the weight station more if you dont have the VIN. stuff like the KYU number and the ICC its not required either but id check with your state your based in directly to see whats required because thats really the main thing you need to follow.
  5. Long FLD
    Long FLD Road Train Member
    12,836
    53,717
    Mar 4, 2015
    You no longer need the VIN in Colorado. I’ve had no issues with my last 2 trucks displaying only the company name and DOT number.
    77fib77, JoeyJunk and Bean Jr. Thank this.
  6. bad-luck
    bad-luck Road Train Member
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    DOT numbers on both sides, you no longer need the MC number on the truck.
  7. Bean Jr.
    Bean Jr. Road Train Member
    5,573
    9,929
    Mar 30, 2014
    Look at the big companies. They put as little as necessary. I used to have our Illinois PUC number, but my most recent, company name, DOT number, that's it.
    JoeyJunk Thanks this.
  8. bad-luck
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    I have the same thing as well. Just my company name and dot number
    Bean Jr. and JoeyJunk Thank this.
  9. abyliks
    abyliks Road Train Member
    4,103
    9,647
    May 2, 2010
    ludlow MA
    I thought CO trucks needed the vin but out of state you were just told to come back in with paper work, I have dot and Mc on the truck with the name but I guess you don’t even need mc any more
  10. Burnt Clutch
    6
    4
    May 6, 2021
    That reminds me about assigned truck and trailer numbers. As far as regulation goes I don't even think they're required. When I called my DOT they said it wasn't. now IDK probably just depends on what you'll be doing with the truck. I was considering taking my truck number off because i dont like the placement on the hood and also I'd rather have less decals. As far as display purposes go.
  11. abyliks
    4,103
    9,647
    May 2, 2010
    ludlow MA
    If you ever load over a scale you want a number so they can save the truck, not required for DOT though IMG_8875.jpeg
    Diesel Dave Thanks this.
