DOT ~ Owner Authority??
Discussion in 'Ask An Owner Operator' started by LillyLoo, Dec 31, 2019.
  1. LillyLoo
    LillyLoo Light Load Member
    88
    28
    Jun 29, 2018
    Hey Truckers,
    Merry Christmas!! Hope all is well. I'm seeking advice on starting a trucking company. We have our own DOT# and also purchased insurance. I would like general professional/experienced advice on running a DOT. Pros, cons, pitfalls. The best way to collect payments from trucker companies, and how to setup payments for multiple drivers. How to handle an audit, etc. Would also like to know how much we should charge to let other truckers use our DOT#?
    Happy New Year
    LillyLoo
  3. JonJon78
    JonJon78 Road Train Member
    7,239
    42,999
    Jul 1, 2018
    Dime a dozen
    Bean Jr. Thanks this.
  4. blairandgretchen
    13,923
    76,484
    Dec 9, 2011
    South west Missouri
    Running a Department of Transportation?
    Do you mean running a trucking company?
    Crude Truckin' and Bean Jr. Thank this.
  5. Long FLD
    Long FLD Road Train Member
    12,827
    53,665
    Mar 4, 2015
    Best of luck with your new business venture.
  6. blairandgretchen
    13,923
    76,484
    Dec 9, 2011
    South west Missouri
    I did some past post research - I think you’re right.
    Crude Truckin' Thanks this.
  7. Chinatown
    Chinatown Road Train Member
    77,643
    184,002
    Aug 28, 2011
    Henderson, NV & Orient
    www.OOIDA.com is a business website for the owner-operator and small fleet owner.
    LillyLoo and blairandgretchen Thank this.
  8. Mahoganyshouse
    Mahoganyshouse Bobtail Member
    15
    4
    Dec 31, 2019
    If you are crossing state lines you will need a MC number which can take 30 days to get. The insurance is very expensive but if you have the start up funds it will be worth it. In my state we had to do an application for the IRP tags and it took three weeks or so to get the tags.
  9. Ridgeline
    22,723
    123,052
    Forget the idea.
    Right now we are going into 2020 with a huge surplus of trucks, trailers and capacity and declining rates.
    Adding to it only screws the rest of us especially with someone who is clueless and will, not might but will end up taking any loads by running on super thin margins that it will make onion skin look like black out curtains.
    brian991219 and Crude Truckin' Thank this.
  10. RunningAces
    RunningAces Road Train Member
    1,304
    2,581
    Jul 2, 2017
    When you lay down at night instead of reading a novel or whatever it is you do before bed read blairandgretchen, double yellow, wonderboy, and farmerbobs thread on being O/O. If you finish all four and still want to do it with no experience in the industry then I'd really encourage you to keep an honest journal of your progress here on TR.
  11. Bean Jr.
    Bean Jr. Road Train Member
    5,573
    9,929
    Mar 30, 2014
    If I understand correctly, your husband has been an owner operator for a little while, and you run the business end of it without much trucking specific experience. Your questions are less "should we do this?" rather "it's a fait accompli, how do I do it?"
    I don't know how much of the business you know and don't know, so I'll start at the beginning, assuming you don't know a thing. First any company that does interstate commerce with a commercial vehicle needs a USDOT number, as well as certain intrastate hazmat carriers. If you will be hauling cargo for hire, you will also need a Motor Carrier docket. It used to be that in addition to having the DOT number on the truck, you need the MC number too. No longer. A company that operates trucks under their USDOT number is required to keep records. Most notably, but not limited to logs, vehicle maintenance and driver records. The FMCSA has loosened the record keeping for one truck owner/driver. These records will be looked at in an audit. Driver logs must be retained for 6 months, then the proper thing for the carrier to do is destroy them. If you have drivers leased on, then you will fulfill the maintenance requirement by getting a monthly recap of maintenance done and the DVIR. Unless your drivers are exempt, you will need to provide a logging service, even though you can charge for it.
    Brokers usually pay only after 30 days, but most offer a quick pay option for a 1-2% discount. There are factoring services, outside companies that pay you for your invoices, again for a discount. There is strong disagreement here regarding using factors. The only thing I will say is that even big companies use factors.
    As far as paying any owner/operators, percentage is easiest in your case, although you may find that charging a flat rate if they book their own freight. Just remember, if you allow them to do that, you may be left holding the bag if they decide to do anything with the freight. They must run under your insurance, but you can charge them. Honestly, in less you are providing something like a fuel card, fuel discounts, financial backing, etc, there really is no benefit to a 1 truck company to lease to a 1 truck company.
    I hope I gave you a little info to start. For more info, read @double yellow 's thread.
  12. 86scotty
    86scotty Road Train Member
    4,699
    12,894
    Aug 27, 2017
    Appalachia
    Why do people continue to feed people's unwillingness to do their own research by responding to posts like this.
    Stop the madness! Lillyloo, learn to search and read!
    henboy1, StrokerTSi, Bean Jr. and 2 others Thank this.
