DPF regen
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Feb 13, 2016.
  1. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    Ive done parkef regen on truck Im driving and was wondering where does all of the ash goes? If it stays in the DPF filter then it will just clog it up.
  3. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Carbon ash trapped in DPF just burns out with high temperature during the parked regeneration. If temperature not enough high or exhaust leaking the DPF will accumulate the ash and clog.
    TheDude1969 Thanks this.
  4. Heavyd
    Heavyd Road Train Member
    7,826
    6,275
    Feb 4, 2009
    The DPF collects the soot, or unburn fuel left over from combustion. During a regen the extra high temps finish this burn to bake off that soot. A fair portion is cleanly converted into heat and the rest burns down into ash. Think of a particle of soot as being the size of a beach ball. After it is baked down the ash would only be the size of small marble. This ash will remain inside the DPF, so yes, there does come a time when the DPF has to be removed and cleaned out.
    Elroythekid, KB3MMX and TheDude1969 Thank this.
  5. Alltransol
    Alltransol Bobtail Member
    15
    9
    Jan 9, 2016
    They are cleaned by high temperature baking and high pressure washing and I've even heard of using lasers.
    The baking process is similar to what is going on in a regen
    Except now they are finding the baking process further breaks down the metal making it brittle so now they are leaning towards replacing it instead of cleaning
    More money out of truck owners pockets
