engine fan runs constant
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Perchie15, Aug 4, 2023.
  1. Perchie15
    Perchie15 Light Load Member
    247
    74
    Aug 16, 2021
    Anybody have leads to why? I did put air to the fan solenoid and it kicks in. It’s in a Detroit dd16 westernstar, not sure what else to look into!! Again the engine fan just stays on all the time! I don’t notice any air leaking?
  3. Lazer
    Lazer Road Train Member
    1,846
    2,975
    Jan 22, 2017
    Is this all of a sudden, or has always done this?
    With the engine off, and air tanks drained, can you spin the fan by hand?
  4. Perchie15
    247
    74
    Aug 16, 2021
    i will have to check this tomorrow. Once I
    The truck is shut off it takes awhile for the fan solenoid to release air so I can spin the fan by hand but once it gets locked in. Ya u can’t. And the a/c isn’t working on it right now but be a little low on Freon so I’m thinking they could be it but don’t wanna fill it up until have the parts.
  5. JB7
    JB7 Road Train Member
    1,001
    1,770
    Dec 13, 2022
    Laurel, MD
    Perchie15 Thanks this.
  6. zinita17601
    zinita17601 Road Train Member
    1,324
    1,613
    Aug 19, 2010
    lancaster pa
    Turn your ac off and check if the problem persists,if it doesn’t the ac is the problem,building too much pressure and the condenser cant keep the temp low enough.
  7. roundhouse
    roundhouse Road Train Member
    3,213
    7,329
    Jul 11, 2018
    I thought Most trucks the fan uses air to NOT spin
    So if something goes wrong with the controls or the air the fan kicks in and runs all
    The time .
    kutscher Thanks this.
  8. Perchie15
    247
    74
    Aug 16, 2021
    The thing is the AC is not working right now I’m waiting on the expansion valve part to come in to replace it but it might be a little low on Freon at like 2 pounds. Also, I had switched out the trinary switch that replaces the high, low pressure, but still no power going to the
    Compressor
  9. Perchie15
    247
    74
    Aug 16, 2021
    To what I found the air once it’s released from the fan, and then the fan stops moving
  10. Perchie15
    247
    74
    Aug 16, 2021
    I pulled the electrical plug off the fan solenoid and it wouldn’t release the air or apply the air by plug it back in. I can spin the fan until the fan solenoid kicks it in then locks it up. Compare to when I pull off the electrical connection.
  11. JB7
    1,001
    1,770
    Dec 13, 2022
    Laurel, MD
    It could be a lot of things. Wiring, module, coolant sensor (there is one that controls the fan)... Best thing to do would be to hook up a laptop and see what is going on. The video below does a good job of explaining possible problems.
    Engine fan stays on. Troubleshoot, diagnose engine fan on a semi truck. Fix an engine fan. - YouTube
