Espar Heater
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Electric, Jan 9, 2026.
  1. Electric
    Electric Bobtail Member
    35
    37
    Jun 5, 2016
    20251031_143345.jpg I purchased a 2023 Peterbilt 389; however, it was built when the heater core was unavailable.
    I have since received the core and had it installed. The heater works; however, it does not heat the truck.
    The mechanic plumbed the exhaust into the vent used during regular sleeper heater operation.
    The area around the unit becomes hot; however, the hot air does not enter the sleeper; it pulls air in through the vent. The steel exhaust outside under the sleeper is working.
    I'm sure further adjustments to the installation are needed to resolve this; the question is where to start.
  3. sirjeff
    sirjeff Medium Load Member
    The Espar heater in my 23' 389 puts out through a vent very close to the heater near the floor.
    I imagine there isnt enough "umph" volume from the bunk heater to make it up through the sleeper hvac ducting
    ducnut Thanks this.
  4. Electric
    35
    37
    Jun 5, 2016
    That's the same vent I'm having an issue with; the hose runs from the heater to it.
    However, when I placed a lit incense stick next to the vent, the smoke went into the vent, not out.
    blairandgretchen Thanks this.
  5. blairandgretchen
    13,926
    76,512
    Dec 9, 2011
    South west Missouri
    I had an Espar in the '01 KW - I don't think they were designed to be plumbed into the existing sleeper ducting.
    It had a separate heated air vent to the sleeper.
    Siinman Thanks this.
  6. blairandgretchen
    13,926
    76,512
    Dec 9, 2011
    South west Missouri
    Then it's plumbed backwards - from memory the Espar had an intake drawing ambient air wherever it was installed, and the hot air blew through a port into the sleeper.
    Did your mechanic read the installation instructions? It's not that difficult.
    ducnut, Siinman and 86scotty Thank this.
  7. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,013
    2,085
    Dec 15, 2021
    Heat will come out the square end,intake is the tapered end.
  8. North Pole Nightmare
    1,013
    2,085
    Dec 15, 2021
    I have an Espar D2,the air duct just makes a loop from below the bunk near the floor.I think it's a 2" duct,maybe a little bigger.Air coming out is really hot if it is set on high.
    ducnut Thanks this.
  9. Brandt
    Brandt Road Train Member
    4,623
    6,358
    Sep 17, 2012
    They blow hot air out. The front of heater right into the sleeper just like 4 in tubing. I would not be surprised if I melted plastic if blowing hot air into sleeper vents. Plus the fan probably not strong enough to blow air thru sleeper vents
  10. KDHCryo
    KDHCryo Medium Load Member
    630
    967
    Sep 14, 2023
    Espar also makes coolant heaters which heat coolant and run it through the standard HVAC ducts.
    Freightliner's parksmart system uses those heaters, they are Espar d4 and d5's. I dunno if Peterbilt ever used those.
    Currently Espar is not shipping replacement units to the USA because of tarriff pricing. Freightliner dealeras are out-of-stock.
    I know, and have froze my buttocks of this winter because I need a replacement espar d5ws for my 2020 cascadia because the coolant flange busted.
  11. cascadia4life
    cascadia4life Light Load Member
    107
    99
    Apr 21, 2023
    Say what? I don't know if the parts store i use had stock or if they got it new sometime ago, but i purchased a brand new espar d5swc for my 2016 cascadia, here in Ontario, Canada. Come to around 1000$ US + labour. I feel your pain. These heaters are very, very, temperamental! they seem to last about to years and they need a cleanup no matter what. I am on my 3rd. And yes, i do multiple full speed/heat cycles year round and it doesn't seem to mater.
    This new one got put in, in the summer, and buddy did not put the brand new heater pump that came with it so it started getting clogged with soot and now i am having issues getting it started. (already changed the fuel pump but now the unit is iffy.....)
    All this to say that you may luck out buying one in Canada if you need it and you should also check ebay. There's plenty of new and use spares!
