Fan clutch
Discussion in 'Trucks [ Eighteen Wheelers ]' started by heavyhaulerss, Jun 18, 2018.
  1. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    97 freightliner ser 60 detroit.
    When a/c is on engine fan stays on. Does not cycle off/on. It stays on. If I turn a/c off fan disengages. If fan is on and I go over 1500 RPM I hear a screeching sound.
    Loose belts, air leak, fan clutch going out ???
  3. Cat sdp
    Cat sdp . .
    21,296
    76,124
    Apr 8, 2012
    Orion's Belt
    Sounds like 2 different problems.....,
    Fan stuck on with ac sounds like high pressure switch/sensor...
    and over 1500 rpms belts squealing sounds like loose belts.....
    But that’s a guess...:-/
  4. blairandgretchen
    13,929
    76,538
    Dec 9, 2011
    South west Missouri
    And - depends on humidity/heat. AC should cycle the fan, but in high heat mine stays on for long periods.
    Belts squealing, personally I’d replace them. I’ve used toothpaste to quiet them before, but ultimately changed them out.
    Tug Toy and heavyhaulerss Thank this.
  5. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    The screeching sound is caused by the belts slipping when the fan engages into high speed.
    The belt or belts may be glazed or loose which is causing the screeching sound.
    Either tighten the belt, replace the belt tensioner, or replace the belt, it all depends on your determination after inspecting the parts.
  6. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Probably what was already mentioned for what sounds like two different problems. I have also seen worn pulley grooves cause some of these type problems. A new belt usually only fixes that problem for a short time. Usually the alternator and I know that is not what you expect. Probably not but look at it.
  7. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,335
    Feb 21, 2015
    Bement, IL
    Don't know that I've ever laid eyes on a 97 Detroit, but if it has a belt tensioner that hasn't been replaced in a long time, it could be the problem as well. Tap it with a hammer handle to help it tighten. If it stops squeeling, change the tensioner.
  8. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    Shouldn’t be staying on for more than about 10-15 seconds bud even on a 95 degree day. Your condenser is probably plugged or debris in there. I recommend getting a heat gun and checking for cold spots all throughout your condenser
    blairandgretchen Thanks this.
  9. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    No tensioner on this engine . It has the bolt you screw to tighten belts. It's new to me.
    RustyBolt Thanks this.
  10. Diesel Dave
    9,643
    32,570
    Jan 20, 2010
    Hesperia, Ca.
    Mine has stayed on longer on hot days. Squealing: loose belts
    BoxCarKidd Thanks this.
  11. Dan0
    Dan0 Bobtail Member
    13
    11
    Jun 11, 2018
    Down south and all around
    The alternator serves as the tensioner on my 97 Detroit.
