Fifth wheel height.
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by spookyFOX, Jul 18, 2024.
  1. spookyFOX
    spookyFOX Bobtail Member
    9
    Jul 3, 2024
    I have a stationary fifth wheel on my 2020 pete. Mechanic said it needs to come up 2.5 inches. Any suggestions. Its a holland fw17. Thanks in advance guys.
  3. Sons Hero
    Sons Hero Road Train Member
    3,018
    30,841
    Jan 8, 2021
    Indiana
    Standup rubber, 24.5” rims
  4. Judge
    91,783
    go to. machine shop they’ll raise fifth wheel with steel drill it and remount with steel between fifth wheel and frame
  5. spookyFOX
    9
    Jul 3, 2024
    Not too sure what you mean by standup rubber Sons Hero. Like get taller tires?
    Have you done something like this before? Trying to figure out the cost effective way to do this correctly.
  6. Judge
    91,783
    Yes, they cut me a square steel tubing and had holes measured and they drilled them out.
    Truck still like that 15+ years later, old truck i drove years ago
    ElmerFudpucker Thanks this.
  7. Sons Hero
    3,018
    30,841
    Jan 8, 2021
    Indiana
    Many O/O will run 22.5 tires with low pro rubber. 24.5s with standard, or standup tires will sit higher, so will buy several inches of height. Probably not the most practical option to switch, fifth wheel could be remounted, or replaced as was mentioned above. What do you pull, tank?
  8. spookyFOX
    9
    Jul 3, 2024
    Ok I'm going to look into taking it to a metal fab shop this weekend. Thanks
  9. spookyFOX
    9
    Jul 3, 2024
    Yessir I pull a tank. It does sound pretty expensive to replace the whole set. My mechanic said it only needs to com up 2 or 2.5 inches. You think tires could do that?
  10. Claytonbigsby
    Claytonbigsby Bobtail Member
    46
    112
    Mar 31, 2019
    We’ve got a set of those fabbed risers we took off a truck years ago, they’ve been collecting dust since they were taken off. If you are interested I can get you measurements and a pic tomorrow, I’m certain they were for a holland frame- if nothing else a pic might get you an idea what they need to look like
    TX2Day and Oxbow Thank this.
  11. Ruthless
    Ruthless Road Train Member
    9,168
    91,041
    Aug 28, 2010
    The City.
    11r24.5 outer diameter is 43.4” mostly
    275/22.5 is about 40”
    that’ll gain you 1.75” nominally
    Might go with a taller stand/riser underneath the 5th wheel plate as another option. Prolly cheaper than both alternatives offered if you labor it yourself by a bunch.
    fleetpride or another parts house ought to have a few options if you check with them on heights available.
    I just changed my fixed fontaine stand from 10” to 6.25”
    /// its setting in the bed of my pickup I’ll put a picture here of what you’d be looking for
    Sons Hero, Oxbow and Bean Jr. Thank this.
