first DOT inspection
Discussion in 'Experienced Truckers' Advice' started by GAShog19, Jan 12, 2024.
  1. GAShog19
    GAShog19 Light Load Member
    54
    17
    Dec 28, 2022
    Englewood, Oh
    So the other day while crossing the scales I got called in for an inspection ... it was only level 3 ... the officer gave me a sheet with the inspection details but didnt have me sign anything ... he has the spot circled at the bottom with my name and at the top it says return certificate to agency listed below ... do I sign this and return it? there is no actual address so where do I return it or do I take it to them? this was the SB I75 Findlay Ohio scale
    this was my first inspection ...TIA
  3. 86scotty
    86scotty Road Train Member
    4,699
    12,895
    Aug 27, 2017
    Appalachia
    Should be an address or phone number on it somewhere. If there were no citations given I don't think you have to bother but someone here will know.
    Rideandrepair Thanks this.
  4. 062
    062 Road Train Member
    6,326
    33,966
    Oct 20, 2013
    Are you a employee or carrier?
  5. GAShog19
    54
    17
    Dec 28, 2022
    Englewood, Oh
    both ... its my own authority
  6. GAShog19
    54
    17
    Dec 28, 2022
    Englewood, Oh
    there is a phone number but no real address ... i can call it and ask
    86scotty and Rideandrepair Thank this.
  7. Rideandrepair
    17,544
    56,839
    Aug 8, 2015
    If there were any violations you must sign, certifying the violations have been corrected and return ( within 15 days) by fax email or snail mail, whatever choices are given. If no violations were found, no signature is required and it doesn’t need to be returned. Either way keep a copy in the office filed under Roadside DOT Inspections.
    nikmirbre, wis bang, 86scotty and 3 others Thank this.
  8. Truckermania
    Truckermania Road Train Member
    1,184
    1,802
    Oct 13, 2011
    Sturgis,SD
    If there were no violations you don't need to do anything other than keep for your records. If there were, there should be an address to send to within 15 days. As an owner operator you can just sign and send in yourself. If company driver you sign, send to your carrier and they have to send it in.
  9. 86scotty
    4,699
    12,895
    Aug 27, 2017
    Appalachia
    That was my thought and experience too but I don't run in every state and I figured it might be different some places. Last level 3 I had was Ohio and didn't have to send in. Usually the officer will tell you.
  10. Diesel Dave
    9,624
    32,407
    Jan 20, 2010
    Hesperia, Ca.
    Didn’t you post this samething already ? No need to start multiple threads…… you must be new.o_O
    DOT Inspection
  11. GAShog19
    54
    17
    Dec 28, 2022
    Englewood, Oh
    wasn't getting many responses there
