Flatbed
Discussion in 'Flatbed Trucking Forum' started by Travis05Lock, Jun 23, 2021.
  1. Travis05Lock
    Travis05Lock Bobtail Member
    27
    28
    Apr 30, 2021
    Maine
    I am thinking about doing flatbed. And I'm thinking about going with TMC. But I'm wondering about how high do you go when you are securing or tarping your load? And does a company like TMC teach you on safety tips and steps on doing stuff like that?
    cke Thanks this.
  3. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    Tmc will do the trick if you want to learn flatbedding "by the book"
    It wont teach you much of the situational weird stuff, but coming out of there if you cant size up almost any non specialized load and secure and haul it, you werent paying attention
    Also, youll learn to tarp, and have plenty of practice, dont worry about that :p
    (Usual max height is 13'6" tarping say hay or insulation. Theres a lot of right ways to do it and as many wrong ways, but many are situational and dependent on the individual)
    ChevyCam, cke, Travis05Lock and 3 others Thank this.
  4. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    Plenty of skate boarders here to give you info. Just wait a bit.
    cke, Travis05Lock and D.Tibbitt Thank this.
  5. supersnackbar
    20,064
    52,358
    Aug 19, 2007
    Your Town, USA
    TMC must have a special class on just securing a tarp. Honestly, most of the TMC's I see have the tightest tarps when I pass them (most, not all)...there are a lot of so-called flatbedders at non-mega companies that could learn a thing or two from them about what a bungie cord is, and how to use the right number of them to secure a tarp so that it isn't waving like a flag going down the road.
  6. skallagrime
    3,855
    9,927
    Apr 10, 2012
    Indiana
    They do, every load in their securement training bay is required to be tarped as well.
    Large coil
    Slinkies
    Cold rolled rod
    Plywood
    Couple others i dont remember
    Then out with a trainer for 4 or 5 weeks as well and they try and make sure you get at least one or two of their most common loads on the road during that time as well.
    Load didnt NEED a tarp, but i didnt like how the small buckets were only plastic wrapped. (Probably one of the only loads ive strapped over my tarps in 7 years (excluding insulation and hay)
  7. Cat sdp
    Cat sdp . .
    21,282
    76,024
    Apr 8, 2012
    Orion's Belt
    Is it true a lot of places don’t want you on top of the load while tarping or securing ?
    Asking for a friend…..
  8. skallagrime
    3,855
    9,927
    Apr 10, 2012
    Indiana
    Nope, they prefer it, even want you to drive by wire from up there so you can see low bridges :p
    God prefers Diesels and D.Tibbitt Thank this.
  9. D.Tibbitt
    156,787
    Yes tmc will show u how to flatbed safely. They do a lot of things that are really not needed but is the extra safe way to do it. Like throwing cross straps on the front of a shingle load ... But it is good to learn how to do stuff safely. Tarping a high load is always sketchy no mattet how many times u do it.. The main thing is u want to eliminate how much time u spend up on top of the load , to as little as possible.... Take it from someone that has fallin off the deck twice .
  10. Moosetek13
    Moosetek13 Road Train Member
    14,957
    18,975
    Nov 1, 2010
    Burnsville, MN
    TMC will also teach you to run at 62-63MPH until a truck tries to pass you at 65, and then speed up when they are next to you to block them.
  11. REO6205
    REO6205 Road Train Member
    13,168
    60,499
    Feb 15, 2014
    California.
    @Travis05Lock ...We'll move this thread to the flatbed section. You've had some good advice so far but I'm sure other guys will add to it.
