Floating or double clutching
Discussion in 'Questions From New Drivers' started by asphaltreptile311, Dec 14, 2016.
  1. asphaltreptile311
    asphaltreptile311 Road Train Member
    1,480
    2,847
    Jun 16, 2016
    Iv learned both floating and double clutching in school is one better on your equipment than the other?
  3. Dumdriver
    Dumdriver Road Train Member
    1,525
    2,138
    Jul 8, 2014
    East Coast
    If you do one poorly, that's worse. If you do one very well, that's better
  4. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Either is fine, as long as you do it well like double d said. Personally i float. Clutch is for 1st n reverse. (Actually whatever forward gear i choose, but that sounds better)
  5. Driver91
    Driver91 Medium Load Member
    479
    287
    Jun 28, 2015
    Floating is a lot better on my left leg I would think lol. Idk never double clutched.
    pattyj, Dumdriver and BUMBACLADWAR Thank this.
  6. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    If you have calf muscles like a Marathon Runner then by all means double clutch.I dont,I float.Nobody,standing on the sidewalk can tell the difference.
    Blackshack46, Wargames and Dumdriver Thank this.
  7. Lonesome
    Lonesome Mr. Sarcasm
    11,679
    24,355
    Dec 15, 2007
    Northern Indiana
    I do both, depending on the situation. And yes, my left knee hurts....
  8. Dave_in_AZ
    423,100
    Depends how tight the tranny is. I've had some newer trucks that I doubled all the time, cause the gear box was so tight.
    I don't believe in tearing stuff up.
    Doubling only requires a nudge. I think its better for the over all life of the truck.
    I do float a lot.
    Now I did 3 years in a manual Pete / 11 yard mixer where I held that clutch, and boy howdy that was a clutch, in for hours at a time, creeping along pouring concrete.
  9. sealevel
    sealevel Road Train Member
    2,664
    10,282
    May 31, 2012
    U.S. 41
    Or you can lightly clutch out and float in. Never understood what the second clutch tap was for.
  10. street beater
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Big truck trannys are not synchronized, there is no "help" to ensure proper gear meshing...
    KillingTime Thanks this.
  11. DustMyBroom
    DustMyBroom Light Load Member
    161
    182
    Oct 11, 2016
    I tend to float on the road and double clutch when negotiating the yard at a shipper.
