Fridge and microwave install
Discussion in 'Questions From New Drivers' started by ThomasTrucker21, Apr 11, 2021.
  1. ThomasTrucker21
    ThomasTrucker21 Medium Load Member
    I didn’t know where to start this thread so I guess this should work. I’m trying to put a microwave and fridge in my truck since It didn’t come with one but both the space for the fridge and microwave both only have 12v plugs. Does anyone have any recommendations or ideas of how I could make It work out?
  3. Arctic_fox
    4,508
    25,450
    Sep 16, 2016
    2000-3000 watt inverter and just drill a hole for an extension cord if you own the truck. If you dont and the company wont let you have an inverter then your basically SoL save for 12 volt coolers
    ThomasTrucker21 Thanks this.
  4. Anywhichwaybutloose
    Anywhichwaybutloose Light Load Member
    159
    265
    Jun 24, 2017
    If there is a cabinet space for the fridge, you can install one there. Dometic is a popular model. It runs on 12v. Many options for a 12 or 120 v option, there are many threads to search for ideas. Microwave will need an invertor.
    NavigatorWife Thanks this.
  5. ThomasTrucker21
    It is a company truck and It does have an inverter I’m not sure how many watts but I will look. For the fridge their is a small area where It could go. Thanks for the input!
  6. Espressolane
    18,667
    116,964
    A hand full of companies make a 12 volt operated refrigerator for trucks. Just get ready to hand out some nice cash for them. If the factory installed inverter is 1500 watts or less, it will have trouble or may not run a small microwave. Start up can be 3 times operating wattage.
  7. Ace Brothstein
    Ace Brothstein Bobtail Member
    33
    242
    Jun 18, 2017
    St. Louis, MO
    I've run a 700 watt microwave on a 1500 watt stock inverter for almost 3 years now. 700 watts is what it throws at the food, it pulls around 1100 watts, (according to the inverter remote). The inverter will run a hotplate, teapot, coffee maker, laptop and multi function laser printer, just never at the same time. I bought a 1500 watt teapot, but it didn't work, had to get an 1100 watt.
    The 12 volt coolers for $100 +/- seem to use a peltier junction with heatsinks and fans. They cool something like 40 degrees lower than the ambient temperature. So if the truck is not running and it's too hot or cold, your food will freeze or spoil inside it. They also ice up easy and need to be defrosted every few days.
  8. ThomasTrucker21
    The inverter in a thermo king one but i don’t know how many watts It is. I’ve been powering my tv with since I got the truck
  9. kemosabi49
    10,977
    47,914
    Jan 13, 2013
    SW Arkansas
    I always had a problem with the cigar lighter type of plugs getting hot and melting after a time. Last couple I had I wired in direct but he couldn't do that in a company truck. And you're right, if you keep the truck below 70 they will freeze you stuff if you aren't opening the cooler door often.
  10. Frank Speak
    Frank Speak Road Train Member
    4,583
    14,117
    May 3, 2016
    I always had the same issue. I did a little research and found that those 12v type coolers aren’t designed to run 24/7 for extended periods. They’re basically for going camping. i went through a couple with neither lasting more than around a year or so.
  11. ThomasTrucker21
    Guess I’ll be buying bags of ice for my cooler then lol
    Rideandrepair and Frank Speak Thank this.
