I don't know where there's leak. I've tightened bolts, rubber cap is on tight and front hubs still seeping a bit of fluid.
Front hub caps seeping fluid
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Jun 19, 2018.
Try removing that cover. So you can see the hub. You may need new seal.
DOT will not like the way it looks. -
You mean gasket between cap and hub?
I did remove cover and tightened up bolts. Is there supposed to be gasket between plastic see through hub?
If it has a clear window, just put a new hubcap on it. Use Permatex Aviation Form-a-Gasket to coat the gasket before installing.
mitmaks Thanks this. -
TA carries most Stemco hubcaps pretty reasonable.
Oldironfan Thanks this. -
New cap seems the best advice.
We found the covers caught all the oil, and water. What we did was make sure the hub wasn't leaking then put a red shop rag behind the cap, that solved that issue.
Slowpoke KW and mitmaks Thank this. -
Been there done that
One tip I was told is that if breather hole in the rubber cap is obstructed it will build up enough pressure in the cap to push out oil
Tug Toy and Oldironfan Thank this.
