Delivered to a Sysco and they rejected 9 cases of Popeyes Mac n Cheese. Filled out OSD form and dispatch told me to toss them. Obviously I don't have the room to store 9 cases of frozen product on my truck but I swiped a couple bags of it. Each bag is about a pound maybe 2. What would be the best way to cook it? I have a microwave and bowls so I was thinking of thawing it out in my fridge and then putting it in a bowl and cooking it that way. Would that work? Or is there a better way?
Frozen mac n cheese
Discussion in 'Food & Cooking in the Truck | Trucker Recipe Forum' started by cdavis188, Dec 23, 2022.
That stuff is typically heated in a steamer, so in boiling water is probably your best option. Once it’s hot, pull the bag, cut it, and dinner will be served.
Sirscrapntruckalot and cdavis188 Thank this. -
Should work.
Shouldn't be any different than if you were heating up left overs from the freezer.
I could be wrong but eh, it's mac n cheese. Can't be that complicated.
In the future if you end up with frozen tacos, I'll be glad to give you my address and send you a package containing pictures of me gleefully eating them.
Sirscrapntruckalot -
AsphaltFarmer, Coffey, Capacity and 1 other person Thank this. -
The problem with microwaving a solid 1-2lb chunk of food is a microwave doesn’t evenly heat. It’ll burn in spots and/or melt the bag.
Usually, food like this is cut out of the bag and put into a steamer pan used in a steam table. A steamer evenly thaws and heats the food, without hot spots or burning it. Likewise, leaving it in a bag, dropping it into a pot of water, then, heating it eliminates burning the food. You gotta’ look at this as an institutional-sized serving of food and heat it like they would.F4T6UY, Sirscrapntruckalot and gentleroger Thank this. -
I kind of figured it was a given to break it up.
Hell, run it under cold water thaw it out some, toss in a bowl, nuke it how you like it.
Or a chisel.
Or find a way to steam it. But that's boring. I like that the OP is taking a non-traditional approach to this.
If anyone needs a mac n cheese fix, but doesn't have time to fix it, I offer to you...
