Fuel gelling
Discussion in 'Experienced Truckers' Advice' started by JC1971, Apr 11, 2016.
  1. JC1971
    JC1971 Road Train Member
    2,682
    9,816
    Jul 29, 2013
    Southwestern U.S.
    I know this seems to be the wrong time of year to be asking this but I was recently in PA when they had this late cold spell in the Northeast.
    I woke up and checked the outside temp display and it said 12 degrees and instantly realized I had forgotten to put anti-gel in the fuel tanks. I was afraid to start the engine because any gelled fuel would clog the fuel filter.
    I called the shop at the terminal and they said to put the anti-gel in the tanks. So, I added the anti-gel and everything was fine.
    It was my understanding that after the fuel has gelled it's too late to add anti-gel and that's when you use the 911, which can only be used by a road service tech or shop for some reason with my company. I don't know if the fuel was gelling, I just assumed that because the temperature was 12 degrees it might be a problem, but maybe that's not cold enough to cause serious issues.
  3. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    Diesel gel up around 10-15 degrees depending on the fuel, what treatment is put in and water in it.
    If it was just a overnight freeze, I wouldn't worry about. I was in PA/NY border last night and it fell below 30 and snowing but it warm up later.
  4. MrEd
    MrEd Road Train Member
    2,196
    2,836
    Sep 2, 2011
    Winfred, SD
    Your filter and fuel lines would likely gel first anyway. So not starting the truck would not really help you any.
  5. AModelCat
    164,566
    Fuel tends to take on a waxy/butter look when gelled. If you shine a light down in your tanks and it looks fluid still you're probably ok.
    JC1971 Thanks this.
  6. JC1971
    2,682
    9,816
    Jul 29, 2013
    Southwestern U.S.
    Never thought of doing that. I guess like a bottle of olive oil if you put it in the fridge.
  7. Blackshack46
    Blackshack46 Road Train Member
    Don't use a torch for light though. Or road flare.
    Mudguppy and tucker Thank this.
  8. TAfool
    TAfool Medium Load Member
    631
    850
    Dec 8, 2012
    He didn't get the memo.....
    Start at 1:15 for the good stuff.
    Sad part is, there are more videos just like this.
    TA
    rabbiporkchop Thanks this.
  9. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    If northern fuel "gelled" at 12 degrees F this nation would come to a standstill in the winters. With northern fuel I don't even begin to worry about issues until forecast lows drop below 5 F for more than about 5 hours of engine off time
  10. STexan
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Sounds like some here are heavily invested in Power Service or other similar company.
  11. TAfool
    631
    850
    Dec 8, 2012
    21 years out and have never had a gel issue. Never added any fuel treatments. I do idle if it gets below 0 to -5f.
    TA
    Starboyjim Thanks this.
