Getting Carded?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Exit310, Jun 30, 2019.
  1. Exit310
    Exit310 Medium Load Member
    537
    244
    Jul 13, 2011
    cullman,alabama
    What is the procedure to get carded @ fuel terminals? Does your trainer decide or does someone that works @ the fuel terminal ride with you?
  3. LDLWells
    LDLWells Heavy Load Member
    782
    1,218
    Jan 14, 2019
    If this is like a refinery, they make you watch an orientation video and your company is responsible for making sure you know what you're doing
    MrJoop, Roberts450 and Exit310 Thank this.
  4. ErieMcDreary
    ErieMcDreary Medium Load Member
    460
    394
    Dec 4, 2016
    Erie PA
    It varies by terminal. Some you just have to request it, others require a 3 time loading with a "trainer" (usually a carded driver) and pass a short test, and anything in between.
    MrJoop, haz-matguru, tscottme and 2 others Thank this.
  5. Exit310
    537
    244
    Jul 13, 2011
    cullman,alabama
    I would be at the Birmingham,Al terminal, i was wanting to know if a manager or Supervisor from the terminal had to watch or ride with me before i get carded.
  6. RoadRooster
    RoadRooster Road Train Member
    4,121
    6,710
    May 10, 2015
    Fort Myers, Florida
    You'll be trained by someone in your company. Then when you've got the system down, someone from the vendor will observe you from start to finish, loading your tank. Then that person will issue your card..
  7. Exit310
    537
    244
    Jul 13, 2011
    cullman,alabama
    When i get carded, if i decide to work for another company will i have to go through the process again or once i`m carded that`s it?
  8. RoadRooster
    4,121
    6,710
    May 10, 2015
    Fort Myers, Florida
    I worked for a jet fuel delivery co. When I left, I kept the cards from the 3 racks where I picked up fuel. If I changed compAnies, I would just notify the rack. They may re-issue a new card or change the employer name on your card. The vendor controls the cards, and fuel jockeys change companies like crazy. The vendors get used to seeing you, and know you, so they make it easy on you and themselves for keeping your card active and current.
    Don't make too much of this unknown...it's pretty simple and painless.
    MrJoop and Exit310 Thank this.
  9. joshuapowell61
    joshuapowell61 Bobtail Member
    15
    10
    Dec 22, 2012
    I'm currently in training with eagle, and I've earned:motiva, kinder-Morgan, and marathon. I've got citgo and Magellan 2 left.
    Here's the 1st one I earned:marathon
  10. joshuapowell61
    15
    10
    Dec 22, 2012
    Just earned another one, and I should have my citgo card by the end of the week. After three weeks I'll finally be out on my own!
    Midwest Trucker Thanks this.
  11. darknessesedge
    darknessesedge Medium Load Member
    650
    423
    Jul 8, 2013
    the card is yours....
    Exit310 Thanks this.
