Ghost dome light?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Irishblood_83, Jan 11, 2021.
  1. Irishblood_83
    Irishblood_83 Bobtail Member
    22
    7
    Jan 11, 2021
    So earlier I stepped out of my truck for about 30 minutes to get something to eat. I open my truck door and close it as usual, and then suddenly notice my dome light kicking on and off slowly. Also at the front of the cab there are some lights above the dash that kicked on and wouldn't go off. I killed the main switch and then my door light kicked on and wouldn't go off. Never seen anything like it in my life....its a brand new 2021 freightliner cascadia. Something to think about is the other day while in Utah I woke up to a dead truck. I kicked on the apu and it almost immediately started which is weird because if they were dead it would have taken a while to charge them I would imagine. Has anyone ever seen anything like this? Thanks in advance for the help.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,541
    6,619
    Aug 26, 2014
    Welcome cus. Sounds like a problem for the dealer.
  4. lester
    2,955
    8,061
    Jan 2, 2012
    NW, Iowa
    If your truck was completely dead why did you apu start? Obviously the apu takes a lot less power to turn over but... I'd check your battery cables, make sure everything is good and tight
    BoxCarKidd and BUMBACLADWAR Thank this.
  5. Irishblood_83
    22
    7
    Jan 11, 2021
    The apu can recharge your batteries if given enough time. It has its own battery, just like the reefer does. I looked at my cables and everything seemed tight. Tomorrow morning I'm going to check them again just to be sure. If I can't find anything maybe stop at a petro or ta and have them test the batteries? What do you guys think?
  6. lester
    2,955
    8,061
    Jan 2, 2012
    NW, Iowa
    I always figured the apu was tied in with the truck batteries..I'd probably take it to the dealer for some warranty work to sort your light issues.
  7. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    Well,I'm going to agree with Lester.It sure sounds like loose battery cables. I think you said " they seemed tight". Take a couple wrenches and verify that they're good and tight.JMO
  8. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    On older models that happened often . The cause was almost always a windshield leaking water into the fuse panels and computers under the dash . On my 09 the horn and wipers got stuck on as well as the lights.
    Crude Truckin' Thanks this.
  9. supersnackbar
    19,989
    51,937
    Aug 19, 2007
    Your Town, USA
    All the APU's I have had always used the truck's batteries, but I have only had a TK, Carrier or Dynasys...so who knows what the other brands have for sure
  10. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,452
    6,846
    Oct 22, 2016
    North Dakota, Eh?
    That made me laugh! Sorry, but that's a funny image.
  11. Irishblood_83
    22
    7
    Jan 11, 2021
    Just an update. The keypad that my company uses for security stopped working, which honestly is perfectly okay with me, and in return the lights stopped doing all the wonky on and off crap. Maybe there was some crossed wires and a fuse popped? Gonna see what happens over the course of the next few days.
    magoo68 Thanks this.
