Grease fitting not taking grease
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Feb 18, 2017.
  1. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    I was greasing my truck and couple of zerk fittings were oozing grease back out once I've greased them up.
    Should they be replaced to fix this problem?
  3. lester
    2,956
    8,076
    Jan 2, 2012
    NW, Iowa
  4. mitmaks
    2,586
    2,102
    May 16, 2014
    It almost looks like small ball bearing in the middle is missing and lets grease back out.
    Oxbow Thanks this.
  5. Ridgeline
    22,721
    122,978
    Shock Therapy and mitmaks Thank this.
  6. lester
    2,956
    8,076
    Jan 2, 2012
    NW, Iowa
    Yeah that happens. Some places it might not be a big deal but I'd just replace the zerks anyway
    Oxbow and passingthru69 Thank this.
  7. tucker
    tucker Road Train Member
    12,647
    40,425
    Jun 13, 2008
    IN
    Seems you heat them up cherry red with a torch and they'll start working.
    Take them off truck first
  8. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    I use one of these on zerk that sometimes don't want to take grease. If I ever have one that the grease squirts out of and it is on a u-joint with two fittings I will go to the opposite zerk and pump grease in while holding my finger over the one that was oozing out and sometimes it will stop it. If not just replace it. Harbor Freight sells a zerk fitting set with various sizes.
    Big_D409, Shock Therapy and mitmaks Thank this.
  9. Powder Joints
    7,982
    8,381
    Sep 25, 2007
    Rosamond, SoCal
    just change the fitting, they get sand n dirt in them
    KB3MMX and Oxbow Thank this.
  10. Powder Joints
    7,982
    8,381
    Sep 25, 2007
    Rosamond, SoCal
    You can buy alot of new fittings for 35 bucks
    cnsper, Oxbow, spyder7723 and 4 others Thank this.
  11. clausland
    clausland Road Train Member
    1,933
    11,068
    Dec 5, 2014
    North Woods
    If it's just that the zerk's bad, that's easy, just change it out....Now, if the grease inside the fitting/pin has fossilized, that's gonna require some heat and some penetrating oil to get things flowing again....Be careful with the heat too...
    KB3MMX, Oxbow and rolls canardly Thank this.
