Greasing Front Springs
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Jan 27, 2020.
  1. Dino soar
    Dino soar Road Train Member
    4,819
    27,072
    Dec 8, 2017
    I have a question about greasing front Springs.
    On the fld120, the rear hanger took grease but it only pushed out on the side near the fitting.
    Everything else pushed out on both sides.
    Is that acceptable for it only to come out on one side?
  3. Goodysnap
    Goodysnap Road Train Member
    3,792
    9,232
    Jul 12, 2017
    Ideally it should purge between both shackles to ensure the pin/bush is thoroughly lubed. I wouldnt go changing it just yet. Run it some and retry it again.
  4. blairandgretchen
    14,018
    77,331
    Dec 9, 2011
    South west Missouri
    Could one jack up - to relieve tension in the suspension, so to speak - on that shackle, then grease?
  5. Goodysnap
    3,792
    9,232
    Jul 12, 2017
    Yup.....sure could. Putting a bottle jack between the frame and spring might do the trick too. The grease will always take the path of least resistance and will likely continue to take the easy way out. I would just keep hitting it often to see if it straightens out.
    A5¢, bzinger, Cabinover101 and 6 others Thank this.
  6. haycarter
    haycarter Road Train Member
    1,920
    5,317
    Jun 9, 2012
    Australia
    That's the ONLY way to grease Front Springs. In My Humble opinion...
  7. Dino soar
    4,819
    27,072
    Dec 8, 2017
    I did grease it with jack stands on the frame and the axle hanging free.
    I think @Goodysnap is correct.
    This truck sat for about five years before I put the engine in and I really went over the whole truck.
    So if I go down the road and let the spring do its work I think it will take the grease.
    While I still have it hanging I can jack the axle a little bit and see if that relieves it, and after I get the wheels back on it and the weight back down on it I'll try the bottle jack also.
    Cabinover101, SAR and Goodysnap Thank this.
  8. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    put a little heat to it. then push new grease threw it.
    Big_D409, bzinger and Cabinover101 Thank this.
  9. Dino soar
    4,819
    27,072
    Dec 8, 2017
    That is one way to do it, but my hangers are aluminum.
    And I think it will take grease once I go down the road with it, if not with the other ways described.
    truckdriver31 Thanks this.
  10. Cabinover101
    Cabinover101 Heavy Load Member
    726
    1,166
    Jul 28, 2019
    Side note/Question ~ I want to buy the DeWalt battery operated Grease Gun. Does anyone have this or use this? I've read mostly good reviews on it.
