Heater Valve
Discussion in 'Trucks [ Eighteen Wheelers ]' started by deckeralliance, May 2, 2016.
  1. deckeralliance
    deckeralliance Bobtail Member
    46
    21
    Apr 8, 2016
    Alright guys and gals, I have a 2004 International 9200i with the 385 horse ism engine. The front heater shutoff valve right behind the dipstick has been leaking, I am trying to find one but I am having zero luck. If anyone could help direct me to right place I'd appreciate it. Thanks!
  3. gunner76
    gunner76 Medium Load Member
    500
    137
    Mar 11, 2010
    IA
    did you take it off and show it to some different parts shops? I would think a truck dealer should be able to match something up. When you find one though make sure to get the 1/4 turn and not the rotary valve.
    blairandgretchen Thanks this.
  4. blairandgretchen
    13,926
    76,508
    Dec 9, 2011
    South west Missouri
    Why are the 1/4 turns better?
  5. deckeralliance
    46
    21
    Apr 8, 2016
    I have been running so I haven't been able to show anyone yet. I was hoping to just find one first so i can just swap it while sitting in line.
  6. gunner76
    500
    137
    Mar 11, 2010
    IA
    They are less prone to leaking than the rotary kind.
  7. blairandgretchen
    13,926
    76,508
    Dec 9, 2011
    South west Missouri
    :) good - that's the one I've got. Shut it off today. Will this improve the AC performance in the cab?
  8. ExOTR
    ExOTR Windshield Chipper Extraordinaire
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    Plumbing stores, commercial hose dealers, Lowe's, home depot etc. There is nothing truck specific about the valve, just cap both ends of the line and take the valve with with you to check diameter.
    deckeralliance Thanks this.
  9. gunner76
    500
    137
    Mar 11, 2010
    IA
    It should help the AC perform better. I always turn off both valves when summer rolls around.
  10. blairandgretchen
    13,926
    76,508
    Dec 9, 2011
    South west Missouri
    Both valves - I found one at the heater core take off by the water pump. I figured there outta be a 2nd one - wonder where it is.
  11. 062
    062 Road Train Member
    6,326
    33,966
    Oct 20, 2013
    On the n14 should be two down low,one may be behind the frame rail. Then two up high by the rear head.
