1. EnglishMark
    EnglishMark Light Load Member
    64
    15
    Feb 15, 2011
    orlando, Fl
    Ok so this may take awhile to explain,
    I got new brakes/drums all round installed on my truck (07 Freightliner Columbia) after I left the shop there is/was a shake in the steering while braking at about 45 mph.. so braking from 65 down was ok till I got to bout 45 then shakes like crazy.
    So after a week I take it back to the shop and turns out my truck was spec'd with x30 drums, they get a set in put them on. No change .. so they call Freightliner in Orlando order new x30 drums for the front and x30 lightweights for the back and allllll new shoes. Installed... No change, .. went to another shop today they checked everything, bearings, kingpins, every engine mount trans mount body mounts, adjusted allllll the brakes and replaced the front slack adjusters (as a last resort) still shakes.
    Tires were new back in October michelins wearing perfectly. They were stumped, I'm over 2500 into this now for a simple brake job. Steering does not shake while driving only braking .. help.
  3. shatteredsquare
    shatteredsquare Road Train Member
    1,407
    1,841
    May 23, 2014
    middle dirt
  4. Judge
    90,915
    Could be an out of round drum, just because its new doesnt mean its good.
    Could be a bad wheel bearing, but yes you said those were checked.
    Try jacking up the front end and see which tire won't spin freely., if they both spin very lightly apply brakes and see which one can't be turned
    EnglishMark Thanks this.
  5. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    This is just a wild guess because it's happened to me.
    When the brake job was done, the drums were installed and then the air was released applying full brake to the drum that wasn't seated to the hub.
    Then when the wheels were put back on it didn't make a complete seat because the brakes were already applied. Might want to check lug nuts too
    Make any sense?
    shatteredsquare Thanks this.
  6. EnglishMark
    64
    15
    Feb 15, 2011
    orlando, Fl
    Judge we did that today, kingpins, bearings all good. These are the 3rd set of drums in 6 weeks .. law of averages says at least one set should of been good.
  7. EnglishMark
    64
    15
    Feb 15, 2011
    orlando, Fl
    Yeah makes sense but we have installed 3 sets of drums now .. plus had the wheels off n on 3 times today, plus drums off today, shoes look great after 2 weeks no odd wear .. I'm stumped.. last resort is take it to Freightliner but I'm already 2500 into this
    6wheeler Thanks this.
  8. Judge
    90,915
    Ok. Who did they brakes?
    Were they put on backwards?
    (Yes it can be done in a hurry and not paying attention)
    Did you use new inserts and springs?
    Or the old ones?
  9. Judge
    90,915
    If it only started when they did the brakes, one shoe is a little shorter, not much, inch maybe, if the first guy put it on wrong, then the next just followed suit, they could still be wrong.
  10. Hulld
    Hulld Road Train Member
    2,884
    6,568
    Oct 19, 2015
    Upstate NY
    If there is any rust or debris on the hub faces the drum will not sit completely flat to the hub and can cause a shutter upon brake application.
    Also one of the aluminum hubs could be bent if they beat the old drums off with a sledge hammer.
    EnglishMark and spsauerland Thank this.
  11. lester
    2,949
    8,032
    Jan 2, 2012
    NW, Iowa
    Wait a second, how can brakes be put on backwards? There's no way
    pushbroom Thanks this.
