Hopper bottom loading
Discussion in 'Questions From New Drivers' started by redcrab, Jul 24, 2021.
  1. redcrab
    redcrab Bobtail Member
    11
    8
    Jul 24, 2021
    I am new too driving and wound up getting into a hopper bottom for awhile. Have my own truck authority and all using the brokers trailer till I get into my own probably something different then hopper bottom but will see. Ran a few loads of corn on my first day went well no problems. Now have a load of natural chicken on and the loader asked me where I wanted it in the trailer. I understand the air gauges on the truck and trailer and need too start recording them as I go I believe. My question is should it be more front hopper loaded rear or even? He wound up loading me more rear hopper heavy then front which rides well but bumpy. Searched the forum and have tried too read up but can’t find any help for my question. The other question is where do you sweep out at on the grates after dumping or how do you clean out without a wash out too be good for the next load? Appreciate any insight or advice on both.
    Trucker61016 Thanks this.
  3. 88 Alpha
    88 Alpha Trucker Forum STAFF Staff Member
    5,595
    18,185
    May 12, 2012
    SouthEast Alabama
    HopperHauler and redcrab Thank this.
  4. redcrab
    11
    8
    Jul 24, 2021
    Tried too send him a message and said I need six more posts too be able too do so. Appreciate the information.
    HopperHauler and 88 Alpha Thank this.
  5. REO6205
    REO6205 Road Train Member
    13,168
    60,499
    Feb 15, 2014
    California.
    We'll tag him again @HopperHauler When he comes online he'll see this thread.
    HopperHauler Thanks this.
  6. redcrab
    11
    8
    Jul 24, 2021
    Perfect thank you also.
  7. Long FLD
    Long FLD Road Train Member
    12,836
    53,717
    Mar 4, 2015
    Just a regular tandem trailer? With a tandem I would load 25k in the front hopper and 27k in the rear. When I pulled my triple axle I’d load 19k in the front and 40k in the rear.
    If you’re loading 25 ton or so then half and half is a good starting point and then go check it on a Cat scale.
  8. 88 Alpha
    5,595
    18,185
    May 12, 2012
    SouthEast Alabama
    Since he is a moderator, you should be able to send him a message regardless of your post count.
  9. redcrab
    11
    8
    Jul 24, 2021
    Yeah just a tandem trailer. Gotcha makes sense and I believe that’s about where I have been but rather ask then be in the dark.
  10. redcrab
    11
    8
    Jul 24, 2021
    When I hit the start conversation on his profile it gave me a count of posts and would not let me.
  11. 88 Alpha
    5,595
    18,185
    May 12, 2012
    SouthEast Alabama
    That's odd.
    He will be on the forum sometime today, will see the tags, and will be glad to help you out.
    You've gotten some good advice so far. Best of luck.
  12. Judge
    91,781
    It depends on how you load.
    Setback axle?
    Or extended hood.
    My Freightliner Cascadia, weighs in around 29000, I usually load it 24000 in front 26000 in rear in order to axle out.
    The Kenworth t660 weighs in 27900, same trailer, it loads half and half to axle out.
    As for washouts I use Bulkloads,
    Where to Get a Truck Washout | BulkLoads.com
    Speed_Drums and HopperHauler Thank this.
