How cold should AC Blow?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TruckerPete1990, Aug 16, 2015.
  1. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,382
    Jul 16, 2012
    Bentonville Arkansas
    So long story short.. AC went out 2 months ago. TA replaced the compressor but wasn't able to replace the dryer as its striped. I got to take off the hoses and replace em. My AC with MAX blows 70... Shouldn't that be closer to 50? What could be causing it to be blowing 70 lol.
    This is a 07 INT 9400i
  3. blairandgretchen
    13,930
    76,540
    Dec 9, 2011
    South west Missouri
    I think 55 is about right. Though, if it's taking in 100+ temps from outside . . .
  4. 062
    062 Road Train Member
    6,326
    33,966
    Oct 20, 2013
    2000 Freightliner on all but the hottest of days 40-42. On smokin hot days 48-50
  5. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    Hmm mine doesnt blow colder then 70.... guess ill have to get it serviced. Without changing my dryer filter could this be the cause?
  6. 062
    6,326
    33,966
    Oct 20, 2013
    Hard to say could be many things,low charge,high charge,not pulling a good vacuum.
    Does the condenser get hot?
    How often does the compressor cycle?
  7. kwswan
    kwswan Road Train Member
    2,027
    11,073
    Jul 26, 2009
    mcminnville,tn.
    Have you got it set to recirculate or fresh air? That will make a difference.
  8. KeithT1967
    KeithT1967 Road Train Member
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    Replace the condenser and orifice tube. They're plugged up with crap from the failed compressor. Ive never seen a 9000 series ih that wouldn't blow under 40 degrees when working right.
  9. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    recirculate air i think its the dryer lines. Gonna buy the lines put em on and recharge and see if that helps
  10. 062
    6,326
    33,966
    Oct 20, 2013
    What was the reason for replacing compressor?
    If it was just the clutch went bad,the rest is probably ok.
  11. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    It was leaking when i bought the truck air was ICE COLD then after 1 month it leaked away to nothing. They said everything else was fine it was just the compressor.
