I cleared it??
Discussion in 'Questions From New Drivers' started by Nsuaqcat, Apr 22, 2020.
  1. Nsuaqcat
    Nsuaqcat Light Load Member
    55
    52
    Apr 11, 2020
    Wyoming
    OK driving down through Austin Texas today my trailer is 13' 6" I come up on a bridge where the right lane is 13 4" and the left lane is 14' 0", The truck behind me panicked and flew in the left lane not giving me any ####ings Room to get over, So I went through the right lane and somehow my trailer cleared it, I still do not understand what happens there is no way that I cleared that but I did
    austinmike and truckdriver31 Thank this.
  3. Judge
    91,668
    some signs are mismarked a few.
    Also If loaded you may not be as high as empty.
    A bridge in Memphis ten on Norris rd says 13’4” but I been under it a ton with a box, good shortcut if someone goes crazy and you get away from 240 midtown back across to 55
  4. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,143
    Mar 5, 2016
    White County, Arkansas
    I am more concerned with the idiot failing to give you room.
    A little bit of luck there.
    Some bridges are real scrapers. Elmira NY comes to mind.
    There have been few that you get under loaded but not empty.
  5. TRS Group
    TRS Group Light Load Member
    93
    117
    Sep 24, 2018
    In Chicago off Stony Island and 95th St there's a bridge that's marked exactly 13' 5 but if you are loaded with at least 30k in a 13' 6 trailer the majority of the time it will clear ...now empty 13' 6 well that's a different story
  6. HillbillyDeluxeTruck
    5,951
    30,432
    Mar 3, 2013
    San Antone
    18,758
    45,959
    Sep 18, 2006
    the road less travelled
    Air ride rides the same height no matter what, as long as the suspension has had time to pressurize or drop excess pressure as after you have adjusted the tandems on the trailer. Most have tolerance from the marked height, indeed, there were places that were marked 13 2 in Chicagoland that would clear a 13 6 and were used as truck detours when construction work was progressing on the Ryan.
  8. Moosetek13
    Moosetek13 Road Train Member
    14,961
    18,982
    Nov 1, 2010
    Burnsville, MN
    I once went under a bridge in NY that had a sign saying the clearance was 12'5".
    About 150 feet before the bridge is where the sign is posted. Faded white on brown and not very noticeable.
    Slam on the brakes and I was a bit under it. Creeped forward and was OK.
    alds, truckdriver31 and Kyle G. Thank this.
  9. Savor the Flavor
    Savor the Flavor Medium Load Member
    651
    2,584
    Nov 2, 2018
    Whaddabout the "minority of the time" it won't clear??
    Axin' for a friend....
    icecold24k, alds, rachi and 4 others Thank this.
  10. TravR1
    TravR1 Road Train Member
    3,695
    9,759
    Nov 9, 2017
    TX
    There's a 13'5 bridge in Joliet IL you can go under at 13'6.
    I stopped before the bridge and just sat there, cursing. There was no good option for getting turned around. GPS was telling me to go under.
    The road looked relatively new paved. So I wasn't too excited about trying my luck.
    A local driver in his POV pickup stopped next to me and told me that I will clear it, just go slow.
    So thats what I did. Cleared it.
    LoSt_AgAiN and truckdriver31 Thank this.
  11. 25(2)+2
    18,758
    45,959
    Sep 18, 2006
    Marked height, unless marked exactly, has some tolerance built in.
    Exactly 13 5 is a question mark, it will clear most trailers marked 13 6 but that measurement is marked a touch taller than is actual, from measuring several on 24.5 low pros and 22.5 low pros. New York was mentioned, the city measured clearance from the center of the axle. Not done enough in up state to know if that follows there, too.
