Inter axle differential left locked
Discussion in 'Questions From New Drivers' started by Canadianhauler21, Mar 31, 2019.
  1. Canadianhauler21
    Canadianhauler21 Heavy Load Member
    864
    1,639
    May 15, 2017
    I noticed yesterday that my inter axle differential was left on for a 1800 mile trip on mostly dry ground. I just had the random urge to check and as luck would have it, the thing was locked. My Qualcomm device basically covers that switch and I gotta move my head under it to see it. I heard it kills your fuel economy but I ended up getting an 8.1 average with it on the whole time.
    Just wondering if I messed something up? You think it's worth mentioning to the company or keeping my mouth shut about it? I work for a mega carrier if that makes a difference.
    I heard some of the new trucks automatically shut it off after some time, but not too sure.
    The truck is a 2016 Cascadia.
  3. blairandgretchen
    13,876
    76,138
    Dec 9, 2011
    South west Missouri
    I think some guys run it locked in all the time.
    I don’t, just engage on soft ground.
    Lepton1 and Canadianhauler21 Thank this.
  4. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,143
    Mar 5, 2016
    White County, Arkansas
    You can absolutely BURN IT UP.
    If it's on dry ground the whole time or worse.
    Have the shop move the switch. Get your mind on your tractor. you probably pulled a little more wear and tear than necessary.
  5. Kw Owners Club
    Kw Owners Club Bobtail Member
    42
    22
    Jan 1, 2019
    Worked for a guy hauling super B and he wanted them left in all the time,I'd turn it off and comeback to work he would have it back in and give me #### lol,never wrecked anything,but manuals n stickers in truck say only run on soft loose ground and not over certain speeds
  6. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Its not gonna do it any harm. If you were talking about a full locker that would be a diff story. Even with the power divider engaged the diff works as an open differential or semi open. Up north its not uncommon to run with it in year round
    okiedokie and Canadianhauler21 Thank this.
  7. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Where's "up north" ?
    Only use mine if can't get started on snow or ice or uneven ground....whatever the case may be.
    Canadianhauler21 Thanks this.
  8. Brettj3876
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Canadian oil patch territory
    Canadianhauler21 and gokiddogo Thank this.
  9. gokiddogo
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Ah. Where real work happens. Never been there :/
  10. wore out
    wore out Numbered Classic
    17,238
    213,384
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Leaving one locked in doesn't hurt a thing. You can engage it at any speed as long as all drive wheels have good traction. When you grenade one is engaging it while one drive set is spinning.
