Is there a speed limit when using axle interlock?
Discussion in 'Questions From New Drivers' started by Bill51, Jan 2, 2022.
  1. Bill51
    Bill51 Road Train Member
    1,185
    2,982
    Jul 27, 2015
    So I've used the axle interlock before, mostly when backing up and you get that back axle lift coming off the street onto a driveway, for a dock, and the front drive axle loses traction. Once I get past the obstacle I'll either stop to turn it off, or turn it off after I bump the dock if the dock is not too far back.
    Watching a trucker driving on an Interstate in snow (don't judge), and he's not going very fast (45ish, safe for conditions) and says he has the axle interlock on.
    Wondering if there is any kind of speed limit for using the interlock.
    And yes, I know you shouldn't use it on dry pavement except for situations like I mentioned above.
    Boondock and truckdriver31 Thank this.
  3. Frank Speak
    Frank Speak Road Train Member
    4,583
    14,117
    May 3, 2016
    Nope, just don’t engage when wheel is spinning (stuck).
  4. AModelCat
    164,434
    Won't hurt anything if its a little slick out.
    In a "perfect world" the interaxle does very little to no speed compensation when running down the highway.
    In reality though, tires are never 100% identical diameters, weights aren't always identical on each tire and suspension components have play in them which can alter the axle alignments when driving around corners. Slick roads allow the tires to slip easier, rather than load the gears excessively and make the oil hot.
  5. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    i drove the whole work week with it in one time 65mph
    Bill51, Boondock, feldsforever and 2 others Thank this.
  6. Frank Speak
    4,583
    14,117
    May 3, 2016
    Not even a water or “winkle” break? You old camel you!
    Bill51, Boondock, Lonesome and 2 others Thank this.
  7. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    ikr. fyi: careful with them foam pilot cups. gets to heavy and they break off in between your fingers
  8. MacLean
    MacLean Road Train Member
    1,380
    4,090
    Sep 12, 2017
    Just gets hard on tires taking turns with everything locked up.
  9. bzinger
    bzinger Road Train Member
    16,649
    66,160
    Dec 10, 2014
    omaha , ne
    Drove mine from omaha to LA to Chicago to omaha once when in the high 400s , 990k on the clock now with no problems .
    Switch is hidden behind the qaulcomm.
  10. Cattleman84
    Cattleman84 Road Train Member
    10,003
    71,357
    Nov 1, 2017
    The Sticks, Idaho
    Shouldnt hurt anything as long as its a little slick out. I have driven, amd know guys that still do drive, trucks with full lockers (inter-axle and differential locks). When it gets really ####ty they will lock it all up and hammer down, never seen one with a problem unless they forgot to unlock it once traction got better.
    Vic Firth, Bill51, Boondock and 6 others Thank this.
  11. Pamela1990
    Pamela1990 Road Train Member
    1,820
    10,721
    Nov 7, 2021
    B.C. Canada
    Running it locked, is just what we call winter, and spring. Basically November till May, just leave it LOCKED.
    4wayflashers, Bill51, Boondock and 3 others Thank this.
