Leaking water pump help!!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by MexTrucka909, Oct 28, 2023.
  1. MexTrucka909
    MexTrucka909 Bobtail Member
    21
    20
    Feb 13, 2018
    24112
    I just stopped for the night
    Noticed leak coming from water pump.. can i still drive like this for 2 hours in order to get to KW dealership?
    blairandgretchen Thanks this.
  3. blairandgretchen
    13,873
    76,104
    Dec 9, 2011
    South west Missouri
    Top radiator off safely with coolant or water if you have to. Do not open radiator cap when hot. Monitor temperature.
  4. MexTrucka909
    21
    20
    Feb 13, 2018
    24112
    THANKS.. im stoped at a ta now.. but they trying to charge 350 just to go get part 2 hours away... so if i could make it tomorrow morning i would get it fixed
    cke and blairandgretchen Thank this.
  5. blairandgretchen
    13,873
    76,104
    Dec 9, 2011
    South west Missouri
    Let her cool off, top up your reservoir and radiator SAFELY - and hit the KW dealership or wherever in the morning. How much coolant are you losing?
    Keep a close eye on the temps as you drive.
    And drive slower than usual - baby it in there. Is the KW open on Saturday - have you called ahead?
  6. MexTrucka909
    21
    20
    Feb 13, 2018
    24112
    Steady little stream coming from bottom mounting bolt... it may be the weep hole
    Isnt losing to much coolant... just trying to avoid paying the delivery fee and get in a better area. Kw opens at 8am tomorrow
    Bud A., cke and blairandgretchen Thank this.
  7. blairandgretchen
    13,873
    76,104
    Dec 9, 2011
    South west Missouri
    Well, get some rest - tomorrow will be a better day.
    cke Thanks this.
  8. JoeyJunk
    JoeyJunk Road Train Member
    8,762
    68,031
    Dec 31, 2010
    Washington, PA
    The KW dealer isn’t going to be any cheaper. They will make their money on hourly labor and whatever other BS they can include. If you can’t do the work yourself you are at their mercy.
    Arctic_fox Thanks this.
  9. 201
    201 Road Train Member
    12,735
    26,191
    Apr 16, 2014
    high plains colorado
    They don't call it a "weep" hole for nothing,,:crybaby:, on coolant leaks, I always left the radiator cap loose, so as not to build up pressure, but modern vehicles don't even have radiator caps. Years ago, if you had 100K on a Cummins BC, a water pump was a regular repair. You should be okay, and get away from the TA!!!
    rollin coal, Diesel Dave and JoeyJunk Thank this.
  10. Arctic_fox
    4,489
    25,284
    Sep 16, 2016
    Your not wrong, but the dealer is a lot less likely to bend him over then the TA insofar as the repair being correctly done....price wise well dealers choice pun intended.
    Me personally id get a couple new 5 gallon buckets, drain my coolant into them then do the pump myself. But not everyone has a small shop rideing shotgun either lol.
    That said it will be fine, especially if you have a MX13. For all the crap i give the MX they are pretty well designed and if the seal fully blows that engine will near instantly shut itself off to protect itself. I think the ISX will too but im not sure.
    Id just pull over every 30 mins or so and check temps and water levels. Also keep your speed low and steady to avoid stressing the rig. However, If you get a big spike in temps or see fluid on the road behind you. Find a safe place to stop ASAP. A ramp or rest area would be best but that means you just dumped all your coolant and your likely going to need a roadside or tow.
    Bring at least a few gallons of coolant with you.
  11. blairandgretchen
    13,873
    76,104
    Dec 9, 2011
    South west Missouri
    Most rigs have a 10-12 gallon capacity. That's a lot of coolant to tote if you have a major leak.
    This big house is a royal PITA for the comforts, but you made me remember a story.
    Turned up to load, another BCO had an issue - helped him change out a lower radiator hose clamp, but due to the heat and size of the hose, lost a lot of coolant. Never met the fella.
    Got it clamped up, but he's short about 5 gallons of coolant, and looks despondent on finding water.
    Me says "Well, I got 40 gallons of fresh water on board to get you to where you can change out to coolant"
    Him (looks stunned) - "You want me to kiss you on the mouth now or later?"
    I added that to my non homophobic vocabulary to express moments of "OMG - you just saved my bacon"
