Load Securement
Discussion in 'Trucking Industry Regulations' started by SyncreonDon, Oct 23, 2019.
  1. SyncreonDon
    SyncreonDon Bobtail Member
    8
    Dec 7, 2018
  3. SyncreonDon
    8
    Dec 7, 2018
    This image is just a sample to show the space. We typically will load these staggered on the trailer. Each rack weighs roughly 500lbs. We do not use any securement devices (they are loaded on special rack buster trailers so they will not bust through) What are the thoughts on this? Is more needed or is this safe?
    We have 1 individual who is refusing to take these loads as he states they are not safe, the normal route driver says he never has issues with load shifting.
  4. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,140
    Mar 5, 2016
    White County, Arkansas
    Stagger those against both walls. IF you can inflate airbags in the gaps of each so all of them will stay put you are good to go.
    I don't have a problem with it. Air bags would make the difference.
    rolls canardly Thanks this.
  5. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,081
    Sep 24, 2019
    Raleigh, NC
    If the racks are tight against each other and secured with load bars on the end they should not fly around.
    The stuff on the shelf however...
  6. rolls canardly
    rolls canardly Road Train Member
    1,624
    3,975
    Feb 7, 2009
    mt. pocono. pa.
    U can never have too much;
    here U are counting on the shelving/cube to be all.
    Add both suggestions above and U are good.
  7. truckdriver31
    6,998
    8,360
    Sep 18, 2013
    i would use a couple of load straps on the back to show good cause and hammer down
  8. Powder Joints
    7,954
    8,306
    Sep 25, 2007
    Rosamond, SoCal
    Yup, without straps or load locks CHP will consider them unsecured.Like the Mail racks I was hauling for a while, strapped every other row with 1 strap, then the last one would get 2 straps. Its up to the driver to make sure the load is secure.
    truckdriver31 Thanks this.
  9. blairandgretchen
    13,755
    74,937
    Dec 9, 2011
    South west Missouri
    That one individual would be correct. Should be prevented from side movement.
    As said, strap each pulling forward, and 2 on rear.
    DOT would probably ticket this.
  10. Studebaker Hawk
    Studebaker Hawk Road Train Member
    3,015
    9,817
    Oct 18, 2010
    NW Indiana
    Everyone here has loaded 8000# rolls of paper on their ends. They just put them on the little rubber sheets and that is considered secure by any and all DOT regulations. The rolls don't touch either wall.
    The friction of the weight of these racks on a wood floor is equivalent. The automotive business loads racks like this all the time, never has been an issue for them either.
    The last ones on the trailer need to strapped/load bars.
  11. truckdriver31
    6,998
    8,360
    Sep 18, 2013
    so why wouldnt the last paper roll not need to be strapped/load bars
