Low air pressure while driving on freeway!?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by PE_T, Jan 26, 2019.
  1. PE_T
    PE_T Road Train Member
    So, one of my air gauges went under 75 psi and a red light and audible warning signal came on. I stopped, waited for the air to build up, checked for air leaks, but nothing. Could it be my air compressor is malfunctioning? This is on a 2014 Freightliner Cascadia with a DD15.
  3. Check your blue return line as well as see if you hear an air leak outside your truck.
    Do you hear air escaping by the red and yellow knobs?
    thaistick and PE_T Thank this.
  4. McMahons Trucking
    McMahons Trucking Light Load Member
    274
    119
    Jul 4, 2018
    Might need to get the governer checked too.
    PE_T Thanks this.
  5. GypsyWanderlust
    GypsyWanderlust Medium Load Member
    386
    568
    Jan 1, 2018
    That is a pretty nasty leak. Find a safe parking place to try and locate the leak. With one parking brake set at a time walk around the truck with the engine off a listen for leaks. After that sit in the truck and release both and watch the pressure while you get on the service brakes. You shouldn’t see more than a 4 psi drop in a minute. Unless it is a loose coupling you can solve, get roadside to fix it or take it to the nearest truckstop if safe enough to do so.
    PE_T Thanks this.
  6. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,143
    Mar 5, 2016
    White County, Arkansas
    If you were able to build air then the compressor is good. And the tanks would hold air. That leaves hoses and connections everywhere else.
    Grab a windex and a rag go around it all with the air built up engine off and see if you can hear and catch leaks.
    Sometimes the leaks would be inside the brake chamber itself. It's not always obvious. If you did find Mr Bubbles showing leak, there is a possibility that you can use a vice grip to loop it off and lock it temporarily until you get to a shop.
    PE_T Thanks this.
  7. PE_T
    Thank you all. I managed to drive about an hour to a Petro, where I was going to luckily shut down for the day anyway. While driving, I noticed the air lowered as usual, but in one ocassion it went a little under 100 psi, but then the air went up somewhat quickly. I think it’s either a severe leak or a truck component is not sending signals for the compressor to turn on.
    Rideandrepair Thanks this.
  8. Rideandrepair
    17,548
    56,859
    Aug 8, 2015
    Probably a brake chamber. Keep a set of vice grips to pinch line and a wrench to back brake off, in case next time you’re too far or the leak is worse. Keeps from getting stranded, still Legal also unless on steer
  9. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Are you in a cold area? Tues I had the same basic issue. Truck lost pressure for a moment, but I was going slow enough to hear the trailer valve pop. Only took a minute or so to equalize the pressure.
    As it only happened that time, I'm guessing a small chunk of ice finally worked it's way out and allowed the trailer tanks to fill.
  10. Rideandrepair
    17,548
    56,859
    Aug 8, 2015
    My trailer brakes grabbed very hard Yesterday when applied normally. Hopefully just the cold weather. Very strange
    PE_T Thanks this.
  11. PE_T
    I was not able to hear any air. I turned off my reefer and truck and was in the middle of no where, so it was very quiet. I moved some of the air lines around, but nothing. Petro is looking at it right now. They didn’t even give me time to check for air leaks thoroughly.
    No, it’s warm right now in south NM.
