Lug nut stud grease
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Apr 23, 2017.
  1. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    Which grease do they use @ shop before they put lug nuts on?
  3. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,382
    Jul 16, 2012
    Bentonville Arkansas
    gear oil works just fine
    Cottonmouth85 and BUMBACLADWAR Thank this.
  4. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    I prefer the Lucas Marine grease on tie rod ends,ball joints etc.Blue color so you can see it.Very water resistant if you drive thru mud puddles etc.
  5. mitmaks
    2,586
    2,102
    May 16, 2014
    Its pretty much anti seize? Cause ive got a can of that
  6. Cottonmouth85
    Cottonmouth85 Bad Influence
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    Nope. Just plain ol' oil does the job.
  7. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    I've never seen a shop apply grease to lug nuts. They are supposed to be torqued "dry", and lubing them up could cause over-tightening, thereby stretching and weakening the studs. If the shop doesn't torque it and just uses their 1" gun to beat the lug nut into place, AND they greased 'er up first, I'd be having them pay for new lug studs, nuts, and potentially even wheels.
    brian991219, Bean Jr. and AModelCat Thank this.
  8. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    Wheel studs are one of many locations on vehicle that are torqued DRY. Read your manufacturers specs.
  9. mitmaks
    2,586
    2,102
    May 16, 2014
    Shop tech used some kind of wax like substance on lug studs when he replaced tires on my truck.
  10. AModelCat
    163,800
    Technically speaking you're supposed to put a drop or 2 of oil between the cone and the flange but that's it. I never put any kind of lube on the threads. Might quickly hit the studs with a wire brush and brake clean/blow gun if they're dirty or rusted.
    brian991219 Thanks this.
  11. bjytech
    bjytech Light Load Member
    245
    222
    Nov 9, 2013
    The flange washer style lug nuts that you see on all the trucks now are spec'ed for a wet torque with a drop of 15w40 engine oil between the nut and flange washer and on the threads, these are the only lug nuts that use a wet torque, all others are dry torqued.
    fargonaz and brian991219 Thank this.
