Major damage
Discussion in 'Flatbed Trucking Forum' started by pavrom, Apr 24, 2022.
  1. pavrom
    pavrom Road Train Member
    3,215
    7,408
    Apr 29, 2012
    NE illinois
    Loaded toyota forklift weighing 39k , 4 chains , strap on forks ...500 miles later one corner damaged my trailer floor and one of the ibeams :(
    What did i miss here or didn't do right?! ...moved forklift all the way back , layed 2 2x4s on each side , rechained ...
    cke, D.Tibbitt, Chieftains and 4 others Thank this.
  3. CAXPT
    CAXPT Road Train Member
    3,367
    15,757
    Feb 10, 2008
    How was it loaded? Driven on or dropped? Sheesh...I don't see how you could have done that with just chaining down, unless it was damaged prior and you didn't catch it?
    Blue jeans, luddybuddy, cke and 2 others Thank this.
  4. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    You should check with the trailer manufacturer to see how many lbs/sq’ that decking is rated for before you roll any more big machines on there. It seems whatever a 39k fork-lift puts on its tire foot print is over that.
    Oxbow, cke, 201 and 6 others Thank this.
  5. Ruthless
    Ruthless Road Train Member
    9,166
    91,007
    Aug 28, 2010
    The City.
    Put the heavy front wheels on a crossmember is something I would consider.
  6. Shawn2130
    Shawn2130 Heavy Load Member
    896
    1,897
    Sep 20, 2015
    Southern Ontario
    That’s a lot of weight on a small area. Especially the counterweight over 2 small tires.
    Probably 12,000 to 15,000 pounds over a 6 inch wide by 3-4 inch tire print and that’s one tire out of two under the counter weight.
    Would’ve busted a wooded floor trailer too if the wood is old or thin enough. Had to repair a 5 axle flatbed wood floor after a heavy forklift drove on.
  7. bumper Jack
    bumper Jack Heavy Load Member
    887
    4,412
    Dec 5, 2021
    What you did wrong was load it on a trailer that was never designed to haul a forklift that heavy. Also you should have cut some 1” plywood and laid it down. It would have spread the weight out and not tore up your equipment. Classic case of in over your head. Lesson learned
  8. pavrom
    3,215
    7,408
    Apr 29, 2012
    NE illinois
    Driven ...very carefully
    cke and CAXPT Thank this.
  9. pavrom
    3,215
    7,408
    Apr 29, 2012
    NE illinois
    Lesson learned !
    Next question : how hard is to replace ibeam considering i have conestoga if that matter ?!
  10. blairandgretchen
    13,926
    76,505
    Dec 9, 2011
    South west Missouri
    Yup - 10k - assuming 40k machine on 4 points - you'd want to spread the weight rather than have a 6" square footprint times four. Especially on aluminum.
  11. Cummins_444
    Cummins_444 Medium Load Member
    605
    1,014
    Apr 28, 2008
    Northwest, IN
    Don't know where you are located. Wayne's tank and trailer repair in Gary indiana is an authorized reitnouer repair point. They fix and have done an excellent job repairing our reitnouers back to new condition.
    cke, Speed_Drums, Blue jeans and 6 others Thank this.
