Manual fan switch
Discussion in 'Volvo Forum' started by Benek, Apr 24, 2018.
  1. Benek
    Benek Light Load Member
    83
    39
    Feb 10, 2016
    Is it possible to put the manual fan switch into the volvo d13,automatic transmission? Been told by a Volvo technician that is not possible, some thing to do with computer programing, I'm no mechanical savvy by any means but I doubt his answer. Any input?
  3. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Search in this forum it possible.
  4. Benek
    83
    39
    Feb 10, 2016
    Thank, will do that, I guess I took the easy way instead of searching first, lazy I'm
  5. sirjeff
    sirjeff Medium Load Member
    You can also do it without any programming. On my vnl, I have a mack fan switch solenoid powered by one of the 3 aux switches (pigtails are under the steering shaft)
    Basically, put the mack fan switch solenoid in line before the Volvo fan one (also under steering shaft area) Now you have a solenoid to override the solenoid!
    Benek Thanks this.
  6. Ridgeline
    22,723
    123,090
    It can be done, talk to another dealer.
    Benek Thanks this.
  7. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    its very simple to do if you have air operated clutch just grab ground from solenoid and run in thru a switch in the dash about 10ft of wiring and 1 hr job, dont always need all the fancy programing and all. all the vecu is doing is cutting out the power to solenoid in order to turn the fan on, you can do the same by taking the ground side and running it thru a switch that way you will break the circuit when you need fan on essentially doing the same thing.
    Benek Thanks this.
  8. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    2008 VNL780 adding manual fan switch
    I also added to my 2016 iShift truck. Works awesome !!
  9. medo1781
    medo1781 Bobtail Member
    5
    Would you happeb to know the part number for that solenoid? Thanks
