Max Burton coffee maker
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Stuka, Jul 5, 2014.
  1. Stuka
    Stuka Light Load Member
    190
    109
    Nov 15, 2013
    Houston, Texas
    Does this work? Anyone use it? I'm looking for max 2 cups, needs to be hot-ish
  3. cuzzin it
    cuzzin it Road Train Member
    3,642
    12,279
    Jan 19, 2008
    Berea, KY
    yup.......
    Stuka and Skydivedavec Thank this.
  4. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Brews in minutes! How many? :)
    Give us review afterwards. Anything is better than a RoadPro.
    Skydivedavec Thanks this.
  5. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    My understanding is any heating that is to be done on 12 volt DC is going to be very slow and inefficient. Whether it's too slow I guess depends on your idea of too slow. A 1500+ watt inverter will run many of smallest [wattage] home units (like the hotel room coffee brewers) if that ever becomes an option.
    Some guys use mini-propane camp cook stoves to boil water, then use a 'french press' coffee pot
  6. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
  7. cabwrecker
    cabwrecker The clutch wrecker
    1,626
    1,425
    Mar 23, 2012
    I just used an enamel coated camp cup, and a few 12v dc water heaters, then the french press.
    Takes a lot of water, though.
    Not for the actual coffee, but rather; cleaning the mesh on the press after its use. Unless you know, you like mold on it.
  8. fishnman
    fishnman Light Load Member
    116
    63
    Sep 6, 2010
    Peoria ,Az
    I used to drive a 2012 Volvo VNL 780 with a 1000 watt inverter. I used a standard Mr. Coffee and regular ground coffee. It worked great.
    f
    blairandgretchen Thanks this.
  9. blairandgretchen
    13,888
    76,208
    Dec 9, 2011
    South west Missouri
    Same system here.
    Tried 12v, no luck - too slow.
  10. Stuka
    190
    109
    Nov 15, 2013
    Houston, Texas
    Yup, it works? Do you use one? Could you describe how it works, the amount of time to brew a cu p? Thanks
    It has terrible ratings on Amazon, but maybe that's because some people think it should perform at the same level as a 110 coffee maker.....
  11. dca
    dca Road Train Member
    6,834
    11,428
    May 31, 2011
    Earth
    I tried one.. got 5 uses out of it then it died.. 20 to 30 minutes to brew.. threw it away... maybe i got lemon tried road pro too. gave that one away. I'm back to a propane burner..
