Minimum Brake shoe thickness
Discussion in 'Trucking Industry Regulations' started by 379exhd, Feb 4, 2013.
  1. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    What's the minimum brake shoe thickness allowed on a CMV? I kept thinking it was 1/4" but I'm not 100% sure. Trailer was just DOT a few days ago so in theory it should be good but a DOT insp. is only worth the money you paid for it if a trooper from carrier inforcement does the inspection imho. Don't want to get thrown OOS for having shoes that are too thin.
    Thanks in advance
  3. Scalemaster
    Scalemaster Heavy Load Member
    808
    1,717
    Mar 13, 2011
    Midwest
    Minimum lining thickness is 1/4" or below the wear indicator on the linings. (3/16" for steer axle with continuous pad)
    379exhd Thanks this.
  4. Sublime
    Sublime Road Train Member
    1,529
    1,896
    Jan 18, 2013
    Twin Cities, MN
  5. Jimmbuds
    Jimmbuds Medium Load Member
    398
    179
    Apr 20, 2009
    Daytona Beach, FL
    What do you mean continuous pad?
  6. Scalemaster
    808
    1,717
    Mar 13, 2011
    Midwest
    Each brake shoe has only one pad (continuous), as opposed to 2 pads per shoe.
    379exhd and Jimmbuds Thank this.
  7. scottied67
    scottied67 Road Train Member
    10,826
    12,675
    Mar 14, 2010
    california norte
    My opinion, put new brakes on once a year. It's only about $200 bucks an axle to have it done, look to have it done when the shops have discounts and sales,write it off on your taxes. Peace of mind is priceless plus the inspector seeing the thick fat brake linings with their flashlight, leaning over the chassis frame is less likely to break out the creeper to get underneath and possible find other things.
  8. 379exhd
    2,925
    3,153
    Jun 25, 2012
    18,758
    45,946
    Sep 18, 2006
    the road less travelled
    I could run mine for 3 years on a set of pads, you are far more likely to have to redo because of getting them oiled than wearing them out, and new brakes aren't immune to that.
    miszel Thanks this.
  10. 25(2)+2
    18,758
    45,946
    Sep 18, 2006
    What happens when the pads get worn past the minimum thickness besides not being compliant? Drum thickness is also figured.
    I already know, just wondering how common the knowledge is.
