N14 celect occasionally shuts down
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by bbennett2665, Sep 7, 2020.
  1. bbennett2665
    bbennett2665 Bobtail Member
    Sep 7, 2020
    1994 White/GMC (Volvo) tandem dump truck with a Cummins N14 Celect diesel and 9 speed overdrive Road ranger trans. The "Engine Fluids" light will come on with a buzzer. The engine will derate and shut down. It will start right up again and may do it again 5 minutes later and it might not do it again for 2 or 3 weeks. There is no overheating problem and all fluid levels are fine. The check engine light has never come on and the diagnostic switch has never shown any codes. There seems to be no rhyme or reason
    to when it does it; idle, slow speed, fast speed, loaded, empty, hot, cold, etc. Doesn't matter.
    Over the past 2 years, we have performed the following work to this truck to
    try to solve this problem:
    1. Removed the instrument cluster, cleaned and applied dielectric grease to
    the harness connection. All of the gauges appear to work.
    2. Removed the low coolant sensor from the coolant reservoir tank, cleaned
    and tested it. It appears to work. Of note, this truck has a 2 pin coolant
    level sensor in the reservoir. The Cummins wiring diagram also shows a 4 pin
    connector which appears to have a factory "shorting plug" installed.
    3. Inspected miles of under hood wiring, cleaned and inspected harness
    connections, checked wire continuity, etc.
    4. Cleaned and inspected the 3 ECM connector plugs. Checked the continuity
    on every wire in plug A, the sensor connector plug. Checked the 12 volt
    inputs and grounds into the ECM,
    5. Replaced the crank sensor, coolant temp sensor, oil pressure sensor, fuel
    shut off solenoid.
    6. Cleaned and checked engine and chassis grounds.
    7. This engine has 3 coolant temperature sensors. One controls the fan. One
    has a factory connector plug on it and goes to the ECM. We're not sure where
    the wires to the third sensor go.
    After all of these repairs, the problem still exists. COULD IT BE A FAULTY
    ECM? The engine ECM for this truck: P/N 3619037, S/N 72557.
    We desperately need to get this truck repaired. If anyone has any ideas I'd be greatly appreciative.
    Brian
  3. blairandgretchen
    13,930
    76,553
    Dec 9, 2011
    South west Missouri
    3rd sensor probably goes to dash guage.
    Sounds like you’ve covered everything I would have.
    Aside from Number 2 - I’d replace that low coolant level sensor, may have an intermittent fault.
    A potentially foolish, but test measure, would be to toggle off the low coolant de rate feature in the ECM, but it’s there as a safety feature.
  4. bbennett2665
    Sep 7, 2020
    Thanks for your reply. Yeah, I'm lost on this one. I'm wondering if something could be going on in the ECM that is sending false info from time to time.
  5. blairandgretchen
    13,930
    76,553
    Dec 9, 2011
    South west Missouri
    Sounds like you’ve covered most bases. I don’t know any N14 ECM specialists - DCS may have answers - Pittsburgh, Pa area - Fernando DeMoura.
    I’m picking a sensor.
  6. xsetra
    xsetra Road Train Member
    5,196
    7,146
    Aug 21, 2011
    The age of motor you might have broken wires inside the insulation of injector/sensor harness.
    I would change the coolant level sensor and check continuity of wires, while you wiggle them.
    If you have the money, I would change the harness also.
    Andreybanyuk Thanks this.
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    We had one with an L10 or M11 doing something like that. Installed a jumper in the coolant level sensor wire connector. No more problems. Replaced the sensor and Volvo White GMC life was good again.
    blairandgretchen Thanks this.
  8. bbennett2665
    Sep 7, 2020
    I truly appreciate all the replies from the group. I rarely let a troubleshooting issue beat me but this one really has me scratching my head.
