N14 overheating
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by wiley coyote, Jun 10, 2018.
  1. wiley coyote
    wiley coyote Bobtail Member
    n14 keeps overheating even on the slightest pull. worked fine 3 weeks ago after replacing thermostats and cleaning debris out of between fins on condenser and radiator. fan doesn't come on till about 205 degrees and AC will run hot air as soon as fan shuts off when idling. Any ideas?
  3. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,544
    May 22, 2017
    Overheating at what temp?
    You may have an air pocket.
  4. blairandgretchen
    13,860
    75,932
    Dec 9, 2011
    South west Missouri
    What temp thermostat are you running?
  5. wore out
    wore out Numbered Classic
    17,162
    211,746
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Check the temp difference across the radiator. (Top to bottom) they should be running the same temp or close. A big difference in temp means poor circulation.
    jamespmack Thanks this.
  6. BigJoeTX
    BigJoeTX Bobtail Member
    27
    16
    Feb 13, 2018
    Katy TX
    When was the last time you flushed your radiator? Could be clogged up.
  7. HopeOverMope
    HopeOverMope Road Train Member
    1,801
    3,211
    Feb 25, 2016
    I-20 LOUISIANA
    Is your water pump belt tight?
  8. xsetra
    xsetra Road Train Member
    5,190
    7,137
    Aug 21, 2011
    Fan comes on at the correct temperature.
    A/C temperature, might be low freon.
  9. DUNE-T
    DUNE-T Road Train Member
    7,034
    17,109
    May 10, 2015
    Detroit, MI
    2nd this.
