Need help.. cruse control/ high idle
Discussion in 'Kenworth Forum' started by mfd560, May 16, 2020.
  1. mfd560
    mfd560 Bobtail Member
    7
    May 16, 2020
    I have a 07 T800 that I run a rolloff trailer with. I use the high idle constantly to speed up the hydro pump. Lately the high idle turns off on its own for no reason. Sometimes the high idle cuts out many times while I’m running the hydros. Can’t figure it out. The cruse control has never acted up while driving down the road. Just the high idle. I’m lost and looking for suggestions. Thanks in advance!!
  3. blairandgretchen
    13,930
    76,560
    Dec 9, 2011
    South west Missouri
    Clutch switch, park brake switch, service brake switch could all be intermittent culprits.
    mfd560 and tscottme Thank this.
  4. mfd560
    7
    May 16, 2020
    Wouldn’t all those things also affect cruse control. Using cruse control hasn’t been an issue. Just high idle.
  5. mfd560
    7
    May 16, 2020
    Would all those things also affect the cruse control?? The cruse control works with no issues. Just high idle.
    blairandgretchen Thanks this.
  6. blairandgretchen
    13,930
    76,560
    Dec 9, 2011
    South west Missouri
    Yes they would. Jakes too.
    I might be looking at plugging to the ECM for a fault code read out, in case there was a parameter affecting the high idle.
    Something is kicking it out.
    mfd560 Thanks this.
  7. mfd560
    7
    May 16, 2020
    It’s going in for overhead work, I’ll have them check it out.
  8. blairandgretchen
    13,930
    76,560
    Dec 9, 2011
    South west Missouri
    Sorry I don’t have any better ideas.
    Certainly post the solution for future reference if you resolve it.
