my truck(2015 freightlinter cascadia eaton fuller smartshift) has power but engine can't be on after an aggressive pedal use. now it is stucked in the middle of the road. fault code 27 shown.
anyone has idea how to reset or solve the problem at least temporarily to get the truck moving?
any help is highly appreciated.
need help --urgent
Discussion in 'Questions From New Drivers' started by selinrosa, Apr 8, 2021.
Did you push the overide button? If not - turn the ignition off, then turn it on. Let the computer cylce through , then start
i didn't try the overide, but tried to turn the key on and offer 6 times as shown in some of the vedios. still no working.Flint1 Thanks this.
just pushed the overide button, still not working. F and N keeps flushing alternatively.
i mean the engine works, but can't go into gear, -
If you have a master power switch, turn it off for 30 seconds. Works sometimes. Did on my Eaton Ultrashift.
feldsforever, austinmike, slow.rider and 1 other person Thank this. -
thank you, but no master power switch on this truck.austinmike Thanks this.
Do you have complete code?
pid 27 is for a turbo. -
fault code 27, clutch disengagement. but don't know how to get the truck start?
I had a KW t660 that did that once. I had to literally take the key out of the ignition for 5 minutes.
feldsforever, selinrosa and slow.rider Thank this. -
Yes there is. It's a dial or knob on the floor between the drivers seat and the driver''s door, near the back side of both.feldsforever and austinmike Thank this.
