Need help with double clutching
Discussion in 'Questions From New Drivers' started by Fmlfrtho, Aug 28, 2019.
  1. Fmlfrtho
    Fmlfrtho Bobtail Member
    32
    12
    Mar 5, 2019
    A little background, Ive driven trucks for almost 15 years in agriculture and have never been taught how to double clutch. The government now wants farmers to have licenses so I'm beginning a training course next week.
    I did the school's assessment a couple of days ago and passed everything except the double clutching portion, which for some reason Im having trouble with, especially downshifting.
    Normally I'd just rev out of gear and rev it until it falls into the next gear, it's very smooth that way. The instructor told me to clutch out of gear, raise the revs up then clutch into gear. I'm having trouble getting it to go into gear smoothly so I'm hoping someone here can offer some advice.
    Thanks
  3. blairandgretchen
    13,926
    76,501
    Dec 9, 2011
    South west Missouri
    Do what you normally do floating, just put your foot on the clutch and lightly press it down as you slip it out of gear - let out, rev up and lightly press as you slip it in the lower gear -
    Basically I'm trying to say - "Make it look like what they want to see happening"
    If that makes any sense.
    I went through a similar situation years ago.
    88228822, tscottme, meechyaboy and 7 others Thank this.
  4. WesternPlains
    6,366
    57,263
    Sep 1, 2017
    Rapid City, SD
    I think that is the thing that gets us. Thinking it's so different from slipping. When it really isn't.
    Think about using the clutch to just take pressure off of the gear change. Keep doing the same you usually do. (like above advise) Add the clutch in it.
    When slipping out of gear. Use the clutch to make it easier on the gears.
    When going into gear. Just wait till after you started revving the engine up. Actually the revving up is just trying to match engine speed. (you already know that)
    You really don't use much clutch at all. Just a little of it.
    I found double clutching helps in situations like hills.
  5. Velos
    Velos Bobtail Member
    22
    16
    Aug 5, 2019
    Watch YouTube videos
    Rideandrepair and Fmlfrtho Thank this.
  6. Fold_Moiler
    Fold_Moiler Road Train Member
    1,926
    3,529
    Mar 17, 2017
  7. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,525
    May 28, 2015
    Yep.
    Even when floating, if you miscalculate, that 2" depression of the clutch can help with the sync as long as the RPM level is in range.
    Happens to the best of us.
    OP.. hopefully you don't have an instructor that wants that clutch to hit the firewall just because the book says so.
  8. Numb
    Numb Crusty Curmudgeon
    4,309
    10,225
    Jan 30, 2012
    Charlotte, N.Carolina
    been driving 35 yrs, don't think I could pass a driving test with these by the book kids.
  9. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,143
    Mar 5, 2016
    White County, Arkansas
    Use your own heart as a timepeice combined with one rpm at torque just above lugging to come out of gear and wait a few heartbeats while engine revs to the high horse RPM speed you need to clutch in next gear. Don't think. Just do and it will do.
    Rideandrepair Thanks this.
  10. DusktillDawn
    DusktillDawn Light Load Member
    68
    46
    May 19, 2017
    Floating and double clutching kinda go hand in hand, same basic principle except when you mash the throttle and come out of gear and rev to go into gear or out of gear you use the clutch to go out, rev then clutch to go in. Just swap your clutch for the throttle?. Easier to watch someone do it and kearn that way
    Rideandrepair and x1Heavy Thank this.
  11. x1Heavy
    34,016
    42,143
    Mar 5, 2016
    He was floating. Now he has to do with the clutch.
    I once tried to float a farmall tractor upgrade.
    The staffers laughed me off the horsefarm. Lesson learned. All I got was a double piston rev in that classic tractor style trying to get up there and then out of gear and fall over half dead. You had to stop stabilize and then get a gear and walk on. Ugh. Tractor (Farm tractor school...) You learn.
