Odometer miles reset
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 09DD60, Sep 8, 2021.
  1. 09DD60
    09DD60 Bobtail Member
    17
    Jun 7, 2021
    I have a 2014 cxu613 with an mp8, noticed my mileage restarts every day to what I started with. So I start at the same mileage everyday, it counts it throughout the day, but then again the following day back to the same mileage 400,xxx.
    (Odometer miles AND trip meter)
    i recently purchased the truck, any ideas to how to fix this?
    Not sure if related but the truck does have a “tune”
  3. streetglider
    streetglider Medium Load Member
    564
    611
    Aug 21, 2011
    Alabama
    Ground hog day! so if you just bought the truck I would say fraud has been committed here, did the seller give you an odometer statement saying that the miles were accurate? chances are that truck has couple hundred thousand miles more on it. I can be fixed but I believe the whole computer needs to be replaced.
  4. 09DD60
    17
    Jun 7, 2021
    My first thought Initially!
    however I have service records from mack dealership that I did confirm al the way up until a few weeks before I purchased the truck.
  5. Judge
    91,152
    Know a guy who did that to a truck.
    Ran it for years.
    Probably had a million miles on it maybe more, but odometer read 556k.
  6. 09DD60
    17
    Jun 7, 2021
    Any clue how he did it so I can undo it lol.
    The accuracy of the mileage is not my concern.
    feldsforever Thanks this.
  7. Judge
    91,152
    Some kind of memory chip in the instrument cluster.. I can’t remember exactly it’s been several years ago, and he died in a vehicle accident.. but I know he did it and the semi he owned was sold after his death
  8. Ridgeline
    22,699
    122,058
    Go to the dealer, only the dealer and get an ECM dump printed out. See what the mileage is. Tell them what's going on.
  9. Magoo1968
    Magoo1968 Road Train Member
    2,055
    5,475
    Mar 18, 2021
    St Malo mb
    Since it’s a 2014 I assume your using elog?? If so go to inspection part and see if ecm mileage changes daily or resets as well. It might give you a clue where to look
  10. 09DD60
    17
    Jun 7, 2021
    I don’t use elog, it’s a daycab and I stay local. Anyother way to check if the ECM is counting the miles?
  11. Magoo1968
    2,055
    5,475
    Mar 18, 2021
    St Malo mb
    Elog puts a mileage at every driving shift change its get it from ecm. My ecm and dash don’t match because cluster was changed. I was just curious if it was your dash messing up or ecm programmed funky.
