Oil change
Discussion in 'Ask An Owner Operator' started by Ikamob01, Nov 29, 2022.
  1. Ikamob01
    Ikamob01 Medium Load Member
    314
    195
    Dec 4, 2021
    Should I run my truck before I change the oil Or change the oil first thing in the morning?
    77fib77 Thanks this.
  3. Judge
    91,864
    More info…
    New to you truck?
    How many miles?
    When did you last change it.
    Where is your current level/texture/smell of oil on the stick?
  4. Ikamob01
    314
    195
    Dec 4, 2021
    Just look at it from a general perspective.
  5. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    Warm oil drains better also drains more gunk out
    Magoo1968, mtoo, Roger McG and 3 others Thank this.
  6. Allow Me.
    10,766
    12,579
    May 28, 2009
    Rancho Mirage, Ca.
    I've done it in my car lots of times. All the oil has drained to the pan, right ? I guess you could argue cold oil will adhere to the pan a little bit, but you will not get every bit of it out. A miniscule amount won't hurt anything. Jiffy lube used to say "10 min oil change" but I prefer to leave the drain plug out for a good 30 min, not 3 min.
    Coolbreezin, Last Call and InTooDeep Thank this.
  7. 77fib77
    77fib77 Road Train Member
    11,641
    76,752
    Jul 7, 2010
    St Louis
    Run it till temp is like 100'F. It won't burn you then and it will flow better.
    Coolbreezin and InTooDeep Thank this.
  8. aussiejosh
    aussiejosh Road Train Member
    4,798
    5,649
    Aug 28, 2009
    Airlie Beach QLd
    Its up to you really it will drain better if it is warm, but you can drain it cold, I'd just wait a lot longer before refilling the crankcase, however personally I'd rather warm it up first, for 15 minutes put some engine oil flush in it if it's an older motor, then drain it. I'm going to go back to changing my own oil after recently getting someone else to do the task not only did they charge like an angry rhino but over filled the sump.
  9. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    Any engine should be warm when draining the oil for service. When filling the engine this is easier as well as the oil drains back fast as the engine is allready warm. Filling a cold engine is very easy to overfill.
  10. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,603
    Nov 11, 2020
    Doesn't matter at all. It's a 13 gallon change, leaving even a gallon in there isn't hurting anything. I stopped changing my oil. I just do filter changes, with a bypass filter. 1 year later, synthetic looks brand new and clear.
    Ikamob01 Thanks this.
  11. lester
    2,956
    8,078
    Jan 2, 2012
    NW, Iowa
    I do both ways, just depends. I like doing it cold if I have the time. If I'm in a hurry I drop it when I get done for the day.
    Funny story. Years ago we were working on equipment. My brother tells this kid "hey go start that stationary engine, let it run for a while then change the oil" kid looks at my brother with a confused look on his face and says "OK but I've never changed oil with the engine running before"
    Ikamob01, Albertaflatbed and Concorde Thank this.
