Oil light
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Perez700r, Mar 3, 2020.
  1. Perez700r
    Perez700r Bobtail Member
    34
    8
    Feb 25, 2020
    I’m having a problem on my 2005 Peterbilt 378 with a cat c-13 the oil light comes on and starts buzzing whenever my rpms are over 1500 but my oil pressure on the gauge is perfect if I drop down below 1500rpms the light and buzzing turn off. Any ideas?
  3. Perez700r
    34
    8
    Feb 25, 2020
    Also my oil level is good.
  4. xsetra
    xsetra Road Train Member
    5,195
    7,146
    Aug 21, 2011
    My guess is bad sensor.
    baha Thanks this.
  5. Jetinc2016
    Jetinc2016 Bobtail Member
    Have to say it’s a sensor somewhere
  6. Perez700r
    34
    8
    Feb 25, 2020
    So maybe a bad oil pressure sensor?
  7. Dave1837
    Dave1837 Road Train Member
    1,402
    4,349
    Nov 16, 2019
    Pennsylvania
    Had the same problem with my '06 379 C15, oil pressure sensor was bad
  8. xsetra
    5,195
    7,146
    Aug 21, 2011
    Yes,if it is original it's 15 years old.
    The other problem could be your pump,BUT you say oil pressure on gauge says good pressure.
    Maybe you can plumb in a gauge you know is accurate to check accuracy of dash gauge and sensor.
    Good luck
  9. Perez700r
    34
    8
    Feb 25, 2020
    I’ll change the sensor out hopefully that fixes it when I change it is oil gonna come pouring out of the sensor hole?
  10. xsetra
    5,195
    7,146
    Aug 21, 2011
    No, the oil should be in the pan, with truck turned off.
  11. xsetra
    5,195
    7,146
    Aug 21, 2011
    Here's a thread with some information.
    Peterbilt forum
    oil pressure C13 Accert help needed
