On duty yard move
Discussion in 'Experienced Truckers' Advice' started by nredfor88, Dec 22, 2021.
  1. nredfor88
    nredfor88 Road Train Member
    1,801
    6,100
    Sep 26, 2019
    USA
    Can OD Yard Move be used after the 14 hour clock is done without triggering a violation? I know regular OD can go as long as you want, haven’t tied YM, but may need to tonight.
    motocross25 Thanks this.
  3. motocross25
    motocross25 Road Train Member
    3,884
    11,939
    Sep 23, 2010
    Overland Park, KS
    From what I was told, yes. “On Duty” is still the prevailing status, “Yard Move” is just the annotation.
    Bean Jr., gentleroger and nredfor88 Thank this.
  4. nredfor88
    1,801
    6,100
    Sep 26, 2019
    USA
    Thank you. I suspected that but verification is welcome. I’m too far to creep, and would be a nuisance trying.
  5. Moosetek13
    Moosetek13 Road Train Member
    14,974
    19,013
    Nov 1, 2010
    Burnsville, MN
    I have done it with the 8 hour clock, but not yet with the 14.
    But it should be the same.
    On Duty YM is the same as On duty, and that does not matter to the 8 or 14.
    You just have to get the proper break in before you hit the drive line again.
    nredfor88 and Bean Jr. Thank this.
  6. supersnackbar
    20,081
    52,463
    Aug 19, 2007
    Your Town, USA
    Our YM stays on 'ON DUTY' as long as you don't exceed 20 mph. Go over 20 and it puts you on drive time. Not sure if 20 mph is a company setting, or a Peoplenet setting or if it'll do that for all ELD's, or if other companies have it set lower or higher. But YM is still ON DUTY time, so you can use it past your 8, 11, 14 and 70.
  7. TripleSix
    133,249
    It’s a company setting. I know of a driver that got caught in a weigh station on YM.
    Bean Jr., InTooDeep and kylefitzy Thank this.
  8. JoeyJunk
    JoeyJunk Road Train Member
    8,762
    68,031
    Dec 31, 2010
    Washington, PA
    I got reprimanded at a previous company using yard move…….while I was on the yard.
    BennysPennys and Suspect Zero Thank this.
  9. Lennythedriver
    Lennythedriver Road Train Member
    2,411
    8,223
    Feb 14, 2020
    According to our safety manager you have to be inside a gated or secured facility to use it, out on the road, anywhere? Nope! Even out front by the gate. Some facilities won’t qualify for its use technically. Of course that’s only if you get a super nitpicky DOT officer or someone reviewing it. Kind of like you hear about them going over fuel receipts, for time on duty while fueling. We hear about it, but does it really ever happen?
    I use it all the time, When I arrive at the shipper or receiver I use on duty yard movement for half of my 10 minutes and then just on duty for the other half. That way I’m saving some of my drive time. And you’d be surprised how much that adds up to an a week.
  10. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    I run omnitracs IVG in my truck and yes I can set the parameters. Assume your company can as well
  11. snowwy
    snowwy Road Train Member
    20,612
    13,330
    Jul 6, 2009
    On duty is as long as you want.
    You just can't drive untill you've taken your break. Should you exceed that time.
    Or did it change recently?
