OTR doing a dedicated route
Discussion in 'Questions From New Drivers' started by Mototom, May 13, 2019.
  1. Mototom
    Mototom Road Train Member
    1,388
    2,703
    May 7, 2019
    I was just wondering if it’s common to make an OTR driver do a dedicated guys run? I was given a 150mile run with 3 stops....and it delivered 3 days after pickup. Not really enjoying the miles with this. Did I mention I hate Maryland.
    x1Heavy Thanks this.
  3. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    coulda been you were in the area and they needed a driver, and you got the route. just do it, you won't be doing it too long.
    RoadRooster and Puppage Thank this.
  4. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    Those guys usually get paid a little better..
    If you're doing more than one load make sure you get paid a bit extra... ;)
  5. Powder Joints
    7,983
    8,384
    Sep 25, 2007
    Rosamond, SoCal
    Its common to grab a truck close by, maybe no one else in the area. Might be a good time to make points for later.
  6. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    It is. If you are the guy that lives close, or just closer than what they have available, then you are the next canidate to take the postion. It isn't about seniority. It's about them making money and not needing to worry about getting you back a long distance for home time.
  7. Western flyer
    Western flyer Road Train Member
    2,807
    6,797
    Mar 13, 2014
    I wouldn’t do it.
    But I’m from a different generation
  8. DenBob
    DenBob Light Load Member
    283
    442
    Feb 19, 2018
    That sort of assignment is not unusual...the dead time is. If it were a one stop delivery I would be asking to deliver early or drop somewhere. But that doesn't sound like a likely option with a 3 stop run.
  9. Moosetek13
    Moosetek13 Road Train Member
    14,976
    19,014
    Nov 1, 2010
    Burnsville, MN
    It's OK to help out once in a while, but you will be taken advantage of every time.
    I no longer do Walmart surge or Target holiday stuff. I turn it down flat. The same with any dedicated garbage, because once they grab you it can be hard to get back out again.
    Just like taking a load to the western states. It is a black hole that that sucks you right down to SoCal and it requires a home time request to free you.
  10. Farmerbob1
    Farmerbob1 Road Train Member
    3,685
    5,792
    Jan 17, 2017
    That's a bit painful and wasteful. They couldn't drop that load in a drop yard or terminal and keep you busy on something else for 2 days?
    Still, sometimes poop happens, and you have no choice but to step in it.
    Turn your acceptance of this load into a better load later. Remind your dispatcher/manager that you took this extremely inefficient load, and that it would be nice if they can get you a nice, long cross-country load to bring your numbers back up.
    You should be able to get a 34 in while under this load as well, which will make it possible for you to roll anywhere in the US without running out of hours on your 70.
  11. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Maryland taint bad. Once Western Maryland becomes the 51st State. //tease.
