Out dated DEF
Discussion in 'Ask An Owner Operator' started by Lazer, Jun 15, 2022.
  1. Lazer
    Lazer Road Train Member
    1,841
    2,973
    Jan 22, 2017
    Anybody know how properly dispose of NOS DEF, and Defendel in totes. At least 3-4 years old. Unfortunately they sat outside in Midland Texas, most of last summer.
  3. RunningAces
    RunningAces Road Train Member
    1,303
    2,581
    Jul 2, 2017
    Your local dump will probably have an area for hazmat drop off. I'd give them a call and check.
  4. 77fib77
    77fib77 Road Train Member
    11,580
    76,176
    Jul 7, 2010
    St Louis
    Many totes? That's a little too much to use a fertilizer, at A persona use level.
    armo and JoeyJunk Thank this.
  5. JoeyJunk
    JoeyJunk Road Train Member
    8,762
    68,031
    Dec 31, 2010
    Washington, PA
    That stuff is safe right? Dump them down the drain. It turns all bad things into good. It’s the cure to all environmental issues I was told. Did someone BS me?
  6. Big Road Skateboard
    7,021
    39,717
    May 2, 2021
    Surely not in truckin......
  7. beastr123
    beastr123 Road Train Member
    2,941
    24,135
    Jan 2, 2014
    Moose Jaw SK CAN
    phone a farmer
    he can top-dress a field or even his garden. some farmers tank-mix herbicides with liquid nitrogen fertilizer(28-0-0) and def is the same thing only 32-0-0 but will need to be pump agitated for a minimum of 24 hours per year sitting. pump should be100 gph.
  8. Judge
    91,349
    Bonfire?
    JoeyJunk Thanks this.
  9. Numb
    Numb Crusty Curmudgeon
    4,294
    10,176
    Jan 30, 2012
    Charlotte, N.Carolina
    sounds like it is biodegradable.
    Noxguard Diesel Exhaust Fluid Safety Data Sheet 20190820.pdf (transliquidtechnologies.com)
    "12. SECTION 12: ECOLOGICAL INFORMATION 12.1 Toxicity Low toxicity to aquatic organisms. 12.2 Persistence and degradability: The product is biodegradable. The product is unlikely to persist in the environment. Urea (OECD 302): 96% 12.3 Bio accumulative potential The product has no potential for bioaccumulation. 12.4 Mobility in soil The product is soluble in water. 12.5 Other adverse effects: None anticipated"
  10. TA1199
    TA1199 Light Load Member
    114
    78
    Sep 12, 2015
    Staten Island, NY
    Shouldn't that stuff be good for the environment? What the hell are we using it for if it isn't!?
    77fib77 Thanks this.
  11. beastr123
    2,941
    24,135
    Jan 2, 2014
    Moose Jaw SK CAN
    It is another use for one type of liquid fertilizer. Unfortunately it is the type that does promote algae and aquatic plant growth in waterways if not processed through dirt based plants first. It is basically a water/nitrogen formula made from dry urea, anhydrous ammonia and water. the nitrogen is one of the trinity of things plants need to grow.
    DEF is an expensive product to use on plants but when outdated (where the urea settles out) product can no longer be used in an engine this is a good way to dispose of it.
    Please do not dump it anywhere near any waterways. nothing that promotes growth should be used within 100 feet of fresh or salt water.
    blairandgretchen Thanks this.
