Overweight load
Discussion in 'Experienced Truckers' Advice' started by jjpaez123, Nov 22, 2020.
  1. jjpaez123
    jjpaez123 Bobtail Member
    24
    11
    Dec 26, 2014
    Driver is claiming trailer is overweight With a single axle
    Could some please give your advise on how we should fix it without removing product from the trailer ?
  3. blairandgretchen
    13,926
    76,509
    Dec 9, 2011
    South west Missouri
    Steer is legal - 12,000 is NOT the limit on steer.
    Drive is overweight. Single dual axle limit is generally 20,000lbs.
    Trailer is slightly overweight - I’d run with it.
    On a 4 axle set up like this - you’ve got to lose about 8,000 lbs.
    How did this situation happen?
  4. jjpaez123
    24
    11
    Dec 26, 2014
    All our loads the weight is 80,000 I don’t know how the driver show up
    With a different tractor
    driver stated his truck is a single axle
  5. blairandgretchen
    13,926
    76,509
    Dec 9, 2011
    South west Missouri
    Wait - please VERIFY TO US that this is a FOUR AXLE setup.
    One steer axle
    One drive axle
    Two (tandem) trailer axles.
    Because - your only input on this forum is asking questions from your driver informing you that he is overweight.
    So, before wasting everyone’s time, and contributing nothing - get it straight.
    magoo68 Thanks this.
  6. blairandgretchen
    13,926
    76,509
    Dec 9, 2011
    South west Missouri
    No - the loads aren’t 80,000 lbs.
    What is the empty weight and axle configuration?
    Who are you - the boss? The driver? A dispatch service?
  7. jjpaez123
    24
    11
    Dec 26, 2014
    I meant to say 40,000 lbs
    I’m the dispatcher
    blairandgretchen Thanks this.
  8. blairandgretchen
    13,926
    76,509
    Dec 9, 2011
    South west Missouri
    Like a dispatch service - not a dispatch for a trucking company - right?
    12+20+34 = 66,000 lbs.
    What is the empty weight of the tractor/trailer?
  9. blairandgretchen
    13,926
    76,509
    Dec 9, 2011
    South west Missouri
    Get Abiel Gutierrez to send you a picture of his truck.
    Count the big black round things. These are called truck tires.
    If there are 18 of them, in a 1-2-2 configuration, then tell him to slide the tandems 2 holes and roll that puppy down the road.
    If it’s a 1-1-2 configuration - then lose his number.
    D.Tibbitt Thanks this.
  10. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    Unless it is spread axle.
    Or in Florida.
  11. blairandgretchen
    13,926
    76,509
    Dec 9, 2011
    South west Missouri
    Good point - 12-20-40= 72,000.
