Paccar MX13
Discussion in 'Kenworth Forum' started by Bsjava716, Sep 11, 2018.
  1. Bsjava716
    Bsjava716 Bobtail Member
    Have a brand new W900 Paccar MX13 510HP. Is there a break in period on these, that at a certain amount of miles they actually gain more power. Almost like engines being held back a little?
  3. larry2903
    larry2903 Heavy Load Member
    789
    994
    Oct 18, 2009
    On the trails
    I have a 15 model, seemed like it started to wake up after the first valve adjustment at 60,000. Every day after that seemed to improve up to about 90,000.
    Is it in a W900 B, or L?
  4. Cat sdp
    Cat sdp . .
    21,292
    76,094
    Apr 8, 2012
    Orion's Belt
    It’s at full power now .....lol.
  5. Geronimo17
    Geronimo17 Light Load Member
    197
    386
    Sep 11, 2018
    KB3MMX Thanks this.
  6. Zeviander
    Zeviander Road Train Member
    4,886
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    510/1850 is the max factory setting for a Paccar MX-13. You might get a little more between 50,000-100,000 if you keep it pulling all the time (no cruise), but they are fairly gutless motors compared to 15-litre alternatives.
    They only really wake up if you remove the thing choking them off.
  7. supersnackbar
    20,078
    52,447
    Aug 19, 2007
    Your Town, USA
    The MX-13 I had at Magnum felt gutless, but honestly, I found myself passing more vehicles on hills than I would have imagined. So, it was pulling, but it didn't have that snap of boost like some of the previous engines I have driven. It was a broader powerband.
  8. Accidental Trucker
    Accidental Trucker Road Train Member
    3,437
    7,789
    Jun 4, 2015
    My t680 has the 510 / 1850 MX13, and I have to agree. Even at max weight (88K) across Oregon, we still kept up with traffic, and were faster up the hills than most. She doesn't feel snappy, but she pulls really well.
    Only complaint is that she starts vibrating around 1200 RPM, so I grab a gear when I get down there, but then again, I don't like pulling down that low anyway.
    I do love the wide power band. Compared to the 500 hp 60 series I drove before, it's way more forgiving to drive, and though the HP rating is the same, the MX13 pulls WAY better. Generally two gears up the hill.
    KB3MMX, Onemanshow and larry2903 Thank this.
  9. DYLAN_131
    DYLAN_131 Light Load Member
    136
    131
    Nov 21, 2018
    As a former Rush Truck Center mechanic, I highly recommend a few things to you; whatever you do avoid unnecessary idling- this leads to excessive soot collecting in the DOC and DPF causing a parked regen (which may not work for you) or a derate.
    Also, I recommend giving it back and getting a w900 with the Cummins X15...
    KB3MMX Thanks this.
  10. Girby6928
    Girby6928 Bobtail Member
    6
    Would it be ok in your opinion for a ten wheel dump truck
  11. Girby6928
    6
    I'm looking at a 2016 579 with 450k. mx13 manual. Turn it into a 10 wheel dump. Any thoughts on this truck for the job.
