Paccar mx13
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Rooster zGreww, Jan 26, 2025.
  1. Rooster zGreww
    Rooster zGreww Bobtail Member
    The problem is the fuel is to hot and it breaks down an plugs the injectors the fuel filter system holds the heat in they need remote spin on filters Diesel breaks down after 126 degrees so your engine runs at 185 plus a fuel cooler could help or they need Bosch to make there injectors
  3. blairandgretchen
    13,926
    76,505
    Dec 9, 2011
    South west Missouri
    Diesel is just fine at 210 f.
  4. Rooster zGreww
    It used to be when it had sulfur in it
  5. NorthEastTrucker
    NorthEastTrucker Road Train Member
    1,016
    1,918
    Sep 21, 2019
    After reading this you're making me wonder at those temperatures would it run better up north here in minus 1 to 4 Fahrenheit temperatures? And if so would tbe longevity be better for the motor?
  6. FLHT
    FLHT Road Train Member
    1,428
    2,544
    Aug 2, 2014
    The motor is a POS and Paccar knows it.
    ducnut Thanks this.
  7. Long FLD
    Long FLD Road Train Member
    12,832
    53,689
    Mar 4, 2015
    The problem with the injectors is that our government has to subsidize farmers and they force junk biofuel on us. They’re not having injector issues overseas like we are here.
  8. Sanders24
    Sanders24 Bobtail Member
    8
    So paccar mx13 its a bad motor?
  9. NorthEastTrucker
    1,016
    1,918
    Sep 21, 2019
    Put it this way, a mechanic at Peterbilt broke it down to me. He said ('Off the record') thousands of the MX13 motors have defective injectors. Head Office knowd this and getting another injector manufacturer making better ones (allegedly). However, like my case they want to know that the motor is bogging down big time nearly shutting off before they fix it by using the limited amount of new injectors regarding the warranty. Honestly, IMO its b.s. I bought a new truck in 2022 in order of avoiding these problems. Yet, here I am. And Peterbilt doesn't reimburse any O/O with shop down time. So its a lose lose situation financially. I should of gone with my initial instincts 'When that Salesman introduced me to Paccar. I wanted to put a Cummins engine in or Detroit in my truck when specced for the order. However the new Cummins motors X15 I'm reading and hearing from mechanics are no good either so Detroit motors seems to be the safest bet. Tows cost to much when adding in the garage downtime. So, I'm staying local 600 mile radius for my freight loads until I know that more of those new injectors are available to replace the garbage ones and using more injector cleaner when fueling up.
    Reason for edit: Typo
  10. mitrucker
    mitrucker Road Train Member
    5,474
    10,270
    Dec 15, 2010
    Lapeer, MI
    Cummings? Is this a new engine manufacturer?
  11. NorthEastTrucker
    1,016
    1,918
    Sep 21, 2019
    mitrucker Thanks this.
