Parallel Parking
Discussion in 'Questions From New Drivers' started by dennisroc, Oct 22, 2019.
  1. dennisroc
    dennisroc Road Train Member
    1,753
    1,257
    Oct 9, 2013
    Anjung-Ri, South Korea
    Looking for good info and videos on parallel parking.
    Straight line and offset are no problem but parallel parking is on and off.
    Sometimes seems real easy but last couple of times I had a little bit of trailer hanging over the yellow lines on both sides.
    Appreciate all info.
    tscottme, truckdriver31 and D.Tibbitt Thank this.
  3. blairandgretchen
    13,929
    76,539
    Dec 9, 2011
    South west Missouri
    There is a formula to it, depending on truck and length of trailer.
    Example -
    At 5mph, pass cones , and at drive axle point, turn wheel 3.5 times to right, straighten trailer, stop.
    Align 'X' cone in passenger mirror, back until "Y', and turn wheel 2 times until backed into spot.
    A good instructor can demonstrate this.
    The real world is totally different (lack of cones).
    Good luck.
    starmac, dennisroc, Dreazz75 and 4 others Thank this.
  4. quatto
    quatto Medium Load Member
    588
    980
    Mar 9, 2013
    The Bluest State
    Parallel parking isn't required on the test in my state, but it seems to me it's almost the same as the offset maneuver without the cone (that represents a parked car or whatever) in front. If you can do the offset you should be able to use the same proceedure for parallel parking, right?
  5. D.Tibbitt
    157,032
    Parrelell parking is the same thing as offset just on the other side and u back it into the side of the box rather than in the front like offset
  6. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    its the same as a car. you both still got to pull up beside the next vehicle
    NavigatorWife Thanks this.
  7. FlaSwampRat
    FlaSwampRat Road Train Member
    4,900
    17,796
    Jun 1, 2019
    Valrico FL
    You in a day cab or a sleeper? I look out the back window to see angle of truck and trailer and where the drive axles are in relation to the curb so I know when to cut it. Sleeper I have no idea, sorry about that.
  8. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    thats un fair.lol
    FlaSwampRat Thanks this.
  9. D.Tibbitt
    157,032
    Sleeper truck if there is a line painted for the box. Or if there is curb Going off what @FlaSwampRat said, when u see the curb/line get just past even with ur back drive tire in ur blindside mirror thats ur cue to turn the wheel and it should slide right in the hole.
  10. WesternPlains
    6,366
    57,275
    Sep 1, 2017
    Rapid City, SD
    No No No!
    You're gonna drive past a parallel parking spot? At 5mph? Then turn the wheel 3.5 times to the right without slowing down? You just ran into the imaginary truck in the front! No!
    Just ram the trailer in there. If you're in a Swift yard. They'll never notice.
  11. 201
    201 Road Train Member
    12,769
    26,263
    Apr 16, 2014
    high plains colorado
    Ok, giving you the benefit of being a new driver, someone is hosing ya'. I don't think I've ever needed to parallel park a semi, 4 ways on and set the brakes. Anything else that doesn't sound quite right, make sure you ask us 1st. Beats looking stupid. "Dude, check it out, I think that guy is trying to parallel park his semi",,,be an internet hit! Whilst learning, I too got funky info from some guys, that wanted me to look stupid. This was obviously before TTR!
    Lostmykey, Milr72, D.Tibbitt and 2 others Thank this.
