Pete 379 not starting please help
Discussion in 'Peterbilt Forum' started by Mikesuburban1, May 26, 2022.
  1. Mikesuburban1
    Mikesuburban1 Bobtail Member
    44
    13
    Dec 30, 2016
    Rockland county ny
    1999 Pete 379 3406e. Been at the spring shop getting work done for 2 weeks. They called me and said the battery's were dead 2 of the 4 battery's had dead cells. I kinda figured before it needed battery's cause they would smell like rotten eggs but anyway they changed battery's. Now the truck won't start. Cranks just fine just won't fire up.... runs if starter fluid applied. Getting fuel pressure at the filter. I did notice the amber engine light was blinking continuously. What does this mean? I can't even pull the codes when using the cruise switches. So now this truck is stuck in there shop and I'm not making money with it soo can someone please help a d tell me where to look
  3. Magoo1968
    Magoo1968 Road Train Member
    2,056
    5,477
    Mar 18, 2021
    St Malo mb
    Did they hook up ecm power or accidentally break wire for ecm..
  4. blairandgretchen
    13,930
    76,560
    Dec 9, 2011
    South west Missouri
    I'd look at ECM fuse or power feed too, if it occurred after a battery swap.
  5. Ridgeline
    22,720
    123,286
    Did they by chance jump the truck with an 12/24 volt jump box with it on 24 volts?
    just got a truck repaired from one of the western states freightliner dealer who used an 12/24 volt jump box and fried the ecm. The idiot mechanic said they use the 24 volt setting all the time when the truck is dead.
  6. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    Light flashes there’s power to the ecm. I’ve got 2 5EK’s that have done that over cam position sensors and a fuel pressure switch. Cam sensor is a good place to start for anything on an E but the fuel pressure switch has caused me a crank/no start too.
  7. Mikesuburban1
    44
    13
    Dec 30, 2016
    Rockland county ny
    So a mechanic came today and couldn't get his laptop to connect to the ecm..... we swapped the ecm with one from another truck he had there and my truck fired right up! So I ordered a ecm this afternoon but can't ship out till Tuesday so hopefully comes in on Wednesday
    baha Thanks this.
