Peterbilt 379 1996 Electrical issues
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jimtx77, Oct 1, 2017.
  1. jimtx77
    jimtx77 Bobtail Member
    38
    Jul 31, 2011
    [email protected]
    My other rig is a 2002 KW T800 with 6nz cat So I am unfamilar with the dash on this pete. Just bought this truck, driving it home. N 14 celect Motor Head lights and top marker lights work as do turn signal, stop lamps and hazards No dash light fuse is good just not getting power thru it. I jumped it across from hot lead and dash lights right up. No Side running lights or rear lights come on . fuse is the push button kind and it is not popped.. Truck has factory chicken lights under cab and flat top sleeper Switches from left to right are Head lights, Cl LPs, Aux lights Load LP Fuel and Spot light. Turned them all on. Any ideas? I opened the dash panel everything looks plugged in.
  3. jimtx77
    38
    Jul 31, 2011
    [email protected]
    I also tested the rear plug before the lights no power no reverse light
  4. blairandgretchen
    13,876
    76,138
    Dec 9, 2011
    South west Missouri
    Is there a round knob next to wiper knob, that is the dimmer switch - is it dimmed to nothing?
  5. jimtx77
    38
    Jul 31, 2011
    [email protected]
    Its all the way to the right
  6. blairandgretchen
    13,876
    76,138
    Dec 9, 2011
    South west Missouri
    I'm guessing the dash lights feed off the 2 left switches - headlights and clearance lights -
    Have you checked power in and out of those switches with a test light?
  7. Hogleg
    Hogleg Medium Load Member
    311
    258
    Nov 20, 2016
    Salem, Illinois
    In how dash lights are lit, at least on my 359, one side of the headlights and one side of the clearance light switch are in parallel with either of them feeding the dash light rheostat. From there they daisy chain across the lights that are snapped into the gauges. There are wiring diagrams avail on the net. www.supermiller.com.
  8. jimtx77
    38
    Jul 31, 2011
    [email protected]
    The problem was in the fuse box, a bad connection in the back. Thanks for your responses
    Hogleg Thanks this.
